Lost key’94 . Any hot wire tricks until I get new key/switch?
Discussion in '3rd & 4th Generation 1990-1997' started by Jim DeFina, Aug 30, 2023.
  1. Jim DeFina
    Jim DeFina New Member
    Well, It has happened… I lost my Ignition.(and gas cap ) keys. Now I’m kicking myself for not making a spare. And I’m scouring eBay for a replacement., which will take a few days to arrive. But this bike is my daily ands I need it to get to work , the gym etc… this may sound like a shady question to ask. But is there a simple way to hot wire the ignition to get her to start without the key? I’m gonna take a look at the schematic to see if there’s something there tat will allow me to tie it all together. If any of you have found a way to do this I’d love to hear about it that would help me out a lot.
    Thanks in advance for all your help.
    Keyless in California.
    Jim
  2. bmart
    bmart Insider
    Charlotte, NC
    If you commute on it, and you're home, and it is home. It can't be far, right?
    We had a saying at the Honda Shop: Red + Red/Black = Green
    At the Ignition Switch plug behind the dash, connect the RD and RD/BK wires.
    Full functionality.
    I always have a jumper wire in my tank bag. Has saved a few people's days, both Fuel Cut Relay and Ignition jumps.
    Also, if you're that far into your bike, if you remove the ignition switch, the key # is stamped in the body, last 3 digits.
    Hope you have a full tank of gas and... (if you haven't already, sounds like you may know it) WRITE DOWN YOUR KEY NUMBER !!!!!! You just need to go to a good locksmith with Make, Model, Year, Key #.
    RogueRC24 likes this.
  4. Jim DeFina
    Yes, Captain 80’s. After looking at the schematic I found the red & red / black = go !
    Thank you .
    And now I’m down to 1/4tank of gas… my previous set of keys had a separate key for the gas tank. Would the ignitionkey # help me with the tank also ? I assume not. If not, is there a way to remove a gas cap without destroying it?
    Thanks for all your help.
    Jim
    No.
    No. (well... any of your friends pick locks?
    Which key is the same as the Seat Latch?
    Now I can definitely say, WRITE DOWN KEY NUMBERS!
  6. Jim DeFina
    There's a few versions of that style cap. I have a couple Vortex that work just fine. Look at Tyga as well.
    Again, which key was the Seat Latch?
