Lower Fairing Replacement Question
Discussion in '5th Generation 1998-2001' started by HellFishTat, Jan 16, 2015.
  1. HellFishTat
    HellFishTat New Member
    Raleigh, NC
    What is the best way to put the rubber grommets (with the threaded inserts) on the new fairing?
    Push them through doesn't seem to be an option.
    Thanks!
  2. TOE CUTTER
    Screw the screw into the grommet a few threads and push on the screw. That's how I do it.
  3. HellFishTat
    Raleigh, NC
    Sounds like a plan. I will try that over the weekend!
    Thanks for the advice.
    Kevin (aka HellFishTat)
