Lower your forks
Discussion in 'Anything Goes' started by chrisallison, Apr 16, 2009.
  1. chrisallison
    chrisallison New Member
    preston England
    If you haven`t already dropped your front forks on the 800 model i can recomend it 100%. Did mine by 5mm it corners better and gives more front end feedback.:thumbsup:
  2. deepdish
    deepdish Banned
    do you lower rear? or front only??
  3. jay956
    jay956 New Member
    Richmond, Virginia, United States
    lowering the rear also would make lowering the front pointless
  4. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    unless you are a shorty and you already lowered the rear, then lowering the front would not be pointless it would just get you back to normal with a little less ground clearance.
  5. squirrelman
    SO ....what i presume you meant but stated ambiguously is that you raised your forks and therefore lowered your front end ??
    I'm doin' minus 10mm on me '86 700..,..seems good 2 me , but i'm a shorty.
  6. jay956
    jay956 New Member
    well it would do nothing for performance
  7. squirrelman
    "Performance"....,.how would u define that??
    It DOES lower the front end and quicken turn-in.....
  8. shaynej
    shaynej New Member
    Hesperia, CA
    5mm? oh crap. that doesn't seem like very much. I dropped mine about an inch and a quarter. Had to do trial and error, since I'm kinda big (6'4" and 250lbs.) dropped it 2 inches to start, rode down the street up to 35mph and WHAMMO, slammed on the front brake HARD! bottomed out. lifted up to inch and a half, 35 mph WHAMMO! bottomed out. lifted up to an inch, 50mph WHAMMO! no bottom out. So put it about 1 1/4" and handles a heck of alot better than before. The front doesn't "look" lowered until it's parked next to another VFR...
  9. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    10 mm over stock, usually 39mm for 4/5 gen is stock, is the most you will really want to go. This is measured from top triple to top fork cap.
  10. Mainjet
    Mainjet New Member
    Southern Ca.
    Raising the stanchions 10 millimeters from the stock position makes a very big difference in turn in. This is the biggest improvement I have made to my 6th gen, and its free.
