"Lump" when turning front wheel while bike stoped.
Discussion in 'Mechanics Garage' started by wolfgrw, May 12, 2010.
  1. wolfgrw
    wolfgrw New Member
    Hi! Not always, but my 2000 VFR800 Fi sometimes does this.. I'm sitting on it, stopped, and when i turn the wheel, it seems that the handlebar turns more than the wheel, almost like there's a "deadzone"... Also, while accelerating, the front suspension is raised, when i brake and the suspension lowers, sometimes i hear and feel a "click" on the handlebar...
    Any ideas? Do i have to swap the direction bearings?
    Best Regards!
  2. Ghost_Rider
    Ghost_Rider Active Member
    LA & Utah
    Check for loose and/or wornout headset bearings. Sounds like the culprit. The bearing or race will sometimes develop a "notch" in the middle from wear, or from a big hit while the headset was loose. You may feel this as you turn the handlebars side to side. Even if you do not, your bearings need attention. I would inspect and/or replace them as soon as possible.
  3. betarace
    betarace New Member
    Middleburg, VA
