Maintenance abuse
Discussion in 'General VFR Discussions' started by hoblick, Feb 21, 2010.
  1. hoblick
    hoblick New Member
    just joking..
    its still winter here in ohio, and i have been on the ball this year with my winter projects.
    so far this winter the VFR has got..
    Brake and clutch fluid flushed and filled
    new EBC HH brake pads all the way around
    check sprockets for wear (great shape)
    New DID xso gold chain
    Valve clearance check/adjust (had 2 out of spec and got them shimmed properly)
    New spark plugs
    clean k&N filter and re oil
    Delete PAIR Valve assembly
    replace water pump (it was leaking)
    flush and fill coolant
    check wheel bearings
    check steering head bearings
    things still to do..
    mount and balance the new Michelin Pilot Road 2 tires (yes i have a tire machine and balancer, totally worth buying)
    change oil (waiting till it gets warmer, dont want to change the oil and have it sit for another month or so)
    it was my first time checking the valves on the VFR.. i have had the bike almost 2 years, and i dont know if they were checked before, so i figured it should be done. I didnt want to pay to get them done either... that and i love to learn new stuff... it wasnt as bad as i thought, i now removving the cams sces some peeople but just take your time, and its no big deal!
    Now its time to finish what i started on my F4i Track bike... its getting sanded down and repainted, and then taken to my cousins shop to get some vinyl done on it.
    so who else got a good chunk of there winter projects done?
    P.S. im dying to go for a ride :cool:
  2. adamjenkins
    adamjenkins New Member
    Massachusetts
    All new fluids--Brake,clutch,coolant,oil
    New Brakes--
    Shock
    Filter-plugs
    Burned out dash light-----that one sucked
    I was going to do valves but I will hold off till later this year
    Still picking-- new tires
  3. reg71
    Sikeston, MO
    lubed the chain, aired the tires, went riding... ;)
    drove 250 miles and bought track bike... drove back 250 miles and unloaded then came on vfrworld to brag about the bike that will sit in my garage more than all the others but will sure be fun on those rare occasions when it escapes...
  4. VT Viffer
    VT Viffer New Member
    South Carolina
    My winter maintenance thus far:
    - Removed PAIR crap
    - Replaced sub air filter
    - Fabricated K&N air filter from OEM & an auto K&N panel filter I had laying around
    - Checked valve clearances, replaced cylinder head cover gaskets/grommets
    - Oil & filter change
    - Removed all plastics for thorough cleaning
    Still need to do:
    - Replace front tire with Michelin Pilot Power 2CT
  5. smack doogle
    smack doogle New Member
    Saint Leonard, Maryland, United States
    -New air filter here
    -flushed clutch/brake lines
    -new coolant (engine ice)
    -oil and filter
    time to ride.
  6. MrDen
    MrDen New Member
    Maricopa, AZ
    I've been trying really hard to get mine cleaned & detailed, but day-long rides keep spontaneously occurring!
