Manual cooling fan switch
Discussion in 'Mechanics Garage' started by Marcegie, Jul 11, 2016.
  1. Marcegie
    Marcegie New Member
    I'm looking to fit a manual fan switch to my 2002 vfr vtec .
    Has anyone done this if so how easy is it to do any tips/advice most welcome
  2. Allyance
    Allyance Insider
    East Bay, California
    I used a heavy duty relay because of heavy current draw. Didn't want to run thick wires and limit choices in switches that could handle current (fan motor is fused at 20amps, so should the switch).
    Actually all you do is parallel the thermal switch in the left radiator, which grounds the motor. Doesn't matter if both switches are closed. For added peace of mind, I added a red LED on dash to remind me fan was on.
  3. squirrelman
    Hundreds have done it. It's very easy, just tap into the wire on the rad, place a switch on the wire, and route the other side to a ground. You can use your imagination to find the best place to mount the switch. :cool:
  4. Allyance
    Allyance Insider
    Hundreds may have done it, but use proper wire and switch to avoid more problems like the stator connectors!
  5. Marrib
    Marrib Insider
    Phx, AZ
    Easy as pie. I also used a 20amp inline fuse. No led to remind me its on. But you can hear it. So, unless you walk away from it for 5 hours, you won't have much of an issue.
  6. NorcalBoy
    Micro switch installed into the stock, left side, switch gear housing. Stock gauge wiring, soldered and shrink wrapped. Nothing fancy, easy to operate without removing your hand from the bar.
    You could also do one of these and mount it to the back of the clutch master:
    http://www.pmrcomponents.com/pmrweb_045.htm
    I have used their stuff and it's rock solid.
    Somebody will probably think it's like running with scissors, but I have used these 10 amp switches on multiple bike fans with no problems.
  7. windunderhawk
    windunderhawk New Member
    Terrebonne
    Hi All, got a 5th gen with a manual fan switch, is the fan supposed to blow out or in? common sense says out.
  8. comradeQuestion
    comradeQuestion New Member
    Oregon
    The OEM fan blows inward. I guess the reasoning is that Honda didn't want the headers to heat up the air before going over the radiator. Some people switch out the fan blades with a VTR one which reverses that.
  9. windunderhawk
    Terrebonne
    Understood, seems to make more sense to have fan blowing with natural air flow.wonder if one could just R&R fan and turn blade over.?
  10. Allyance
    Allyance Insider
    You can’t just turn the fan over, I got a fan for another model (can’t remember) and put manual switch and relay to turn fan on manually on my 6th gen. All that is required is to parallel the thermal switch in the left radiator, use a relay because motor draws a lot of current, otherwise you will need heavy wire and a 20 amp switch.
