Marc Parnes wheel balancer
Discussion in 'Mechanics Garage' started by reg71, Jul 31, 2006.
  1. reg71
    Sikeston, MO
    Fed up with paying someone else to balance your tires?
    Wish you could put your new tires on yourself and have it done your way, when YOU want it?
    If this is you, then read this: (btw this is not an ad, I'm just trying to be funny)
    Ok, so I saw some talk about marc parnes portable wheel balncer in the mailing list forum so I decided to check it out. It was a minimum of $30 per tire to get it done locally so I started doing the math, and after my 4th tire, I have made up the cost... That is, assuming my labor is free. ;) There's always a catch.
    Here's my take on it. This is a nice little gadget. I'll include attachments and I'll post another how-to on changing the front tire from start to finish so you can read more about it, too. The actual wheel balancing procedure is pretty straight-forward. Wheel weights are $2 a strip at my dealer, or $2 from marc when you order your balancer.
    Marc, answered any e-mail he got from me in less than 24 hours and even offerred to walk me through my first balance on the phone. Now that's customer service. I didn't take him up on it, but I appreciated the offer.
    You can see in the attachment that the device is pretty small so you can tuck it into a small toolbox and forget about it until the next time you get ready to balance a tire.
    You can see in the pics, I just placed the balancer on 2 jack stands, but you can use something else. Just make it level.
    Anyway, the purchase price is around $135 and I can do front and rear. He also makes special adapters for different bikes. For instance the rear of a vfr so my balancer came with an additional part.
    If you are into doing it yourself, and don't count your labor, go for it. However, getting the old tires off and new tires on can be bothersome. See my how-to to see the mistakes I made. It works well, the price is not too bad, and the customer service is great.
  2. mello dude
    Romania
    Hi Reg, how's it going?
    I have wondered about that static thingy like you have. I have offen seen it in RidersWear House (the aerostitch guys). How does the balance job work out? Whadif you so happen to see - oh just maybe a buck forty on your speedo, do you notice any out of balance vibs? Just curious. - I have for years gone to a local house that has a high speed spin unit dedicated for bikes that works out well.
  3. reg71
    Sikeston, MO
    I went up to 135 or so for a few secs, I didn't notice anything, but I wasn't there long. I'm about to go for a ride so maybe I'll hold it a little and see. I usually don't ride there, but for the sake of science... Anything in particular you want me to look/feel for?
  4. mello dude
    Romania
    I usually dont spend a lot of time there either, but there are a few roads here where you can hold it for a minute or two. I was just curious because I've had the dealer do it statically and it shook noticably. So u will definately notice a shake if its out.
    This is the geek side of me, but a spin machine tyde to a PC would seem to be the way to go. Then again it may be overkill.
    Keep the rubber side down.
    Later
  5. reg71
    Sikeston, MO
    That does sound a bit overkill, but to each his own. I just did a little riding, but I still haven't hit any high speeds yet. Bike feels much more stable. Seems to take a little more effort to turn then before, but holds a line well. I should add that I stiffened up my rear shock and turned the preload up front 1/2 turn also when I replaced the tires...
    Later that same day...Ok, so I went out again and got up to indicated 145 for a few secs. No noticeable vibrations from the tires. I was tucked in and it was about as smooth as I have done that speed on any bike.
    Always try to. :)
  6. DonnyBallGame
    DonnyBallGame New Member
    Nashua, Iowa
    This is simular to how the "Pro's " do it at the track. Whe I go to Road America I see the Dunlop and Michelin guys mounting hundreds of tires for the racers. They all static balance them. If that is good enough for them on the track @ 180 mph, it should be good for me at my slow 75 MPH.
