Marker light bulb replacement 2003, how to:
Discussion in '6th Generation 2002-2013' started by thethaw, Apr 21, 2014.
  1. thethaw
    thethaw New Member
    sunny Tampa Fl.
    on my new to me v-tech vfr 800..., asking this...after spending 1/2 hour trying to turn it.....accessing thru the black access plate on the inner fairing, how do you get the bulb out to replace??? ...did a thread search, found nothing...thanks in advance for informed responses
  2. 34468 Randy
    Were you able to remove that black panel. It is held in there only by one of those silly faring clips.
    Then you reach inside and give the socket a quarter turn and the bulb and socket just pop out. A little finicky if you have large fingers.
    If that isn't doable, it may be easier to remove the side faring and access it much easier that way. You want to make sure you engage the socket back into its spot securely or it is likely to vibrate out of place.
    The bulb is a blade type that should come out of the socket with some gentle wiggling back and forth and pulling out
  3. thethaw
    thethaw New Member
    sunny Tampa Fl.
    just got it.....had to spray plastic protectant/dressing all over the socket fitting....to make it a bit slippery...then it turned...still a lot of force applied to turn....but its out....
  4. Badbilly
    The bulbs are not screw type bulbs. They have "ears" or pins. The sockets or receptacles are spring loaded. Try pushing down on the bulb and twisting to the left. Worst scenario is that the assembly is corroded.
    If this is still confusing, go to a Honda parts supplier and call up a drawing of the assembly and take a look at the replacement bulb you may or may not have already.
    Or you can take it to your favorite friendly dealer and lighten your bank account by mucho pesos because they will tell you the bulb is really expensive and the labor takes about an hour. @ 250 pesos por hora.
