Mirror Extenders
Discussion in '5th Generation 1998-2001' started by mcrider18, Jun 2, 2012.
  1. mcrider18
    mcrider18 New Member
    Hopefully riding a motorcycle...
    With a 6' 3" height and a sleeve length of 37", I needed mirror extenders to be able to see behind me. Well, I decided more is better and installed both the (1) SW-MOTECH extenders and the (2) mirror base spacers from Burkhart Cycle. Now I can clearly see around my arms and everything behind me. In addition to to being positioned outboard, they're also a little higher than stock.
    SW-MOTECH, $71.50, SW-MOTECH mirror wideners (Honda CBR600F4i, '99- / CBR900RR,'98- / RVT1000 / VFR800 / VTR1000) - SVL.01.500.100 : TwistedThrottle.com
    Burkhart Cycle, $23.00, Honda VFR800 1 mirror spacers, extenders 2000-2001 - $23.00 : burkhartcycle.com, Motorcycle Parts and Accessories
  2. highway star
    highway star New Member
    North Mississippi
    Yes, great mod! I have the base mount extenders too, helps tremendously!
  3. Cyborg
    Cyborg New Member
    I have the SW-MOTECH extenders only but being 5' 8" I LOVE them!
  4. VIFFER RIDER
    VIFFER RIDER New Member
    Socal
    Has anyone tried using 2002 factory mirrors? They sit higher up and in a different position, the bolt pattern for the mirror appear to be the same as the 98-01
  5. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    I have the condom mirrors on my 99, in very good condition,thinking of adding extenders, should I change for the newer type mirror and extenders now? there are extenders available for the condom mirrors,
    just not sure if I should bite the bullet and upgrade all round.
  6. raYzerman
    raYzerman Member
    Millgrove, ON
  7. NorcalBoy
    I had that same type of design on a 6g. I copied the shape of the bottom of the mount and drew a cad file. Made them 30mm thick and had them cnc'd out of aluminum, then powdercoated them the same color as the fairing. The program removed a lot of the excess material on the inside and they ended up super light and I attached them with ti tapered socket head bolts. It turned out decent and I liked the way the color made them blend as part of the fairing. The mirrors almost looked like they were floating off the fairing from a distance.
    The later style mirrors would be a good update, I just don't have any experience mounting them on a 5g.
    VFRIRL likes this.
  8. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
