Mirror Replacement 6th Generation
Discussion in '6th Generation 2002-2013' started by StealthBoss, Apr 19, 2021.
  1. StealthBoss
    StealthBoss New Member
    I searched for this exact thread title and found none so we have mine. I just got my VFR and unfortunately, I dropped it while moving it on its right side and the mirror broke off so I bought a Honda OEM. I do not mind them on this bike since 2007 marks the 25th anniversary of the VFR.
    I also took the exhaust off this weekend in lieu of a new slip-on.
    I wanted to ask a couple of quick questions.
    First, do I need to remove the upper cowling plastic piece behind the mirror mount to catch the nuts inside when taking off the old mirror?
    Also, for this generation do I need to do anything to the O2 sensors when changing the exhaust to a slip-on?
    I have to say this bike sounds amazing without the exhaust I mean when I ride it sounds ridiculously like a muscle car! Here is a short clip of it running.
  2. Berwolf
    Berwolf New Member
    Nope you can just remove the bolts and swap the mirror. I had the same thing happen and replaced both, pretty straightforward.
    Sent from my Pixel 3 using Tapatalk
  3. StealthBoss
    Thanks, that piece was simple to remove and I found out the nuts are welded. Great!
