Mirror ?
Discussion in 'General VFR Discussions' started by RVFR, Feb 14, 2016.
  1. RVFR
    Was wondering if anyone has tried to pull / pried the mirror off it's socket ? I'm thinking over some mirror ideas here and seems just maybe if one was to be able to get the mirror housing off the stock arm, then just maybe there would be some other options. But seeing how it is probably attached when the housing is very warm. trying to pull it apart cold or even heat gun warm, ain't happening. Then the chance the mirror won't take the stress, taking it to a place of no return. any way just wondering?
  2. Grumpy old man
    Grumpy old man New Member
    New Zealand
    Cambridge, New Zealand
    Just smash the Glass and undo the nut
    Then you can replace the mirror head with another with a built in indicator but the wire will have to run along the outside of the arm unless you can get someone to drill the arm out to accept the wire internally
  3. RVFR
    No kidding, they are held on with a nut you say, Hmmm....
