It looks like the Mobil 1 M1-108 is a direct replacement for the Honda OEM oil filter. Has anyone used this filter? Anything different between Honda and aftermarket brand? Thanks.
I know the ones they make for cars are good. But I don't think there is anything wrong with the Honda ones, so there is really no need to switch.
i use the M1-108 on both of my bikes, and have for years. you can also look at the M1-110 if you have an extra inch of clearance where the filter goes. the ONLY difference between the 108 and the 110 is that the 110 is about an inch longer/taller than the 108. same diameter, same thread on the filter, same everything else.
