Mods for Ethanol in your bike?
Discussion in 'Mechanics Garage' started by bladrnr, Aug 11, 2008.
  1. bladrnr
    bladrnr New Member
    Santa Rosa,CA
    Would the Mods be the same on a bike as a car? Would you just change the fuel lines? Has anyone tried it in their bike? How does it work for you?
    :vader:
  2. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    E85 is not compatible with aluminum either, but your FI bike might be ok there. That's one of the reasons carbureted bikes can't run it. Ethanol likes to eat aluminum and brass (if I remember correctly), of which there is a lot of both in carburetors. Don't be surprised if you have some o-rings and other seals in the system that would also need to be changed in order to run E85.
  3. derstuka
    San Diego, CA
    Ethanol, is very corrosive to certain metals (as Jamie mentioned), and would likely cause some problems if you did not do some changing of fuel lines, certain o-rings, aluminum parts, etc....
    Can I ask why you would want to do this? Just to have more fuel options. Ethanol has a lower energy density than gasoline, so expect a drop in MPG of probably 15-20% I would say on average, as well as a drop in power output.
  4. cjheap
    cjheap New Member
    It also attracts water which will rust your fuel tank ( ask me how I know), goes bad fast and will varnish your fuel system.
    Due to E10 , which is mandated here , I am having to replace my tank, fuel pump and carbs on my 91:mad:
    I am going to have to start running avgas to get non ethanol fuel.
  5. Nitrousva
    Nitrousva New Member
    Richmond
    Also take into account that when you convert from gas to alcohol, you'll need to burn twice as much fuel to get the engine running right. I don't think the computer in your bike can compensate that much, but you will see a 20-30 percent increase in torque.
  6. bladrnr
    bladrnr New Member
    Santa Rosa,CA
    just hoping to do my part
    I just wanted to know if it was possible. I was hoping to do my part in getting off foreign oil. It's supposed to a little cleaner. And according to the IRL ethanol has increased their mileage.
  7. bladrnr
    bladrnr New Member
    Santa Rosa,CA
    It sounds riskier than I hoped. Like I said the IRL says they are not having any problems putting it in their HONDA engines. Power and corrosiveness have not been problems and they use a lot of aluminium. I was hoping they already made all their engines semi compatible with with e85 since e10 is already in california gas. The nearest e85 retailer is 50 miles away from me anyway. Just trying to be proactive. Are there any bikes that are ready for e85 yet? I know all this is pretty new.
  8. Gears
    Gears New Member
    Western PA
    The IRL may say that the Honda engines are not having any problems running ethanol but remember their engines only have to last 500 miles or less.
  9. cjheap
    cjheap New Member
    Ethanol is not cleaner and is an environmental nightmare. For one, it takes 1700 gallons of potable water to produce each gallon.
  10. derstuka
    San Diego, CA
    I am not sure where the IRL is getting their info. It has a lower energy density than gasoline (you can check this out just about anywhere), so I don't know how that they can claim that. Ethanol from sugar cane (Brazil, major producer) has more energy than our corn ethanol though. As the article below states, you can bump up the compression because of the higher octane, but it still will not best gasoline in mileages. You would need to burn lots more ethanol to equal the energy output of gas. As someone stated....short term, I can see it being ok to run without problems....long term....that is where the issues might arise.
    Some ethanol facts (from website):
    Exact Low Energy Content of Ethanol
    With only 2/3 the energy of gasoline,
    ethanol costs more per mile
    The energy of ethanol relative to gasoline
    A. 76,000 = BTU of energy in a gallon of ethanol
    B. 116,090 = BTU of energy in a gallon of gasoline
    C. .655 = 2/3 = GGE of energy in a gallon of ethanol. A / B.
    D. 1.53 = Gallons of ethanol with the energy of 1 gallon of gasoline. D = B / A.
    The basic story on ethanol mileage and cost
    Some Ethanol proponents claim it doesn't hurt their mileage, but this goes against physics, and you will not find the ethanol lobby making such fraudulent claims--they could be sued. But just to be sure, zFacts analyzed all of EPA's ethanol mileage tests for one year and, big surprise, ethanol gave exactly 2/3 the mileage of gasoline.
    Now there is one possible loophole and it is used by a Swedish sports car, the SABA 9-5 Bio-power. Here's the trick. Higher compression ratios make engines more efficient, and because of its high octane, ethanol can take a higher compression ratio. The Bio-power is turbo charged and when it uses E85 it switches to a higher compression ratio. It still gets fewer mpg on ethanol, but it does a little better. Unfortunately it's very expensive. An easier approach is to use diesel, which also gives you a high compression ratio and mileage as good as a hybrid at less cost. That's why all big trucks are diesel.
    The USDA tells us that ethanol cost 57¢ more per gallon on average over the last 25 years (and it still does). Put that together with the fact that it takes 1.53 gallons to equal a gallon of gasoline.
    23% extra fuel cost of using E85 with 2006 models
    The EPA has measured the gas mileage of 2006 flexible fuel models. For the 31 models they tested the average reduction is 26% fewer miles per gallon. For example a car that gets 30 mpg on regular would typically get 22.2 mpg with E85. This is exactly what is predicted from the fact that E85 has less energy per gallon than gasoline.
    For these calculations, the EPA assumes that E85 costs $2.00 and regular $2.20/gallon. Obviously they are on the low side, especially for ethanol, but this proportion is similar to what DOE predict for the next few years. The loss in mileage more than makes up for the cost savings, and on average the EPA predicts driving on E85 will cost 23% more than driving on regular.
    Here's a letter from someone using only E85.
    He's getting slightly worse mileage than predicted by ethanol's low energy: 2/3 the energy of gasoline. But Sam has been fooled by the deceptive (but true) claim that Ethanol has high octane and thinks he should actually get better mileage.
    Sir;
    I have a 2003 Chevrolet Suburban. The ONLY fuel I have used on this vehicle is the Ethanol 85, and I am not happy.
    1.) I have seen that in other states the price of Ethanol is LOWER than regular gas. I go to the gas station in Annapolis, Maryland on West Street. The price for this fuel is $1.95 per gallon. The regular gas price is $1.43 per gallon in my area.
    2.) This fuel is rated at 100 Octane and SHOULD result in better fuel mileage. My vehicle is rated from 16-22 MPG. Since I have gotten this vehicle and using this fuel I cannot get ANY better than 13.2 MPG.
    I believe in this program and want to continue to support it. I am a retired police officer and not made of money. My friends laugh at me and call me a fool. They say my intentions are great, but NOT at that cost.
    SAM WALTERS
    Annapolis, MD.
    This letter was posted by National Ethanol Vehicle Coalition. They answered, but did not tell him why he was getting low mileage—they don't want people to know.
    This is what the Iowa Dept. of Agriculture (bottom of page) tells us:
    "E85 is priced to be competitive with 87-octane gasoline. In Iowa, prices typically range about 8-10 cents more than regular unleaded."
    Even at the same price, E85 would be 41% more expensive than regular gasoline.
    Ethanol has only about 2/3 the energy of gasoline
    The lower heating value (LHV) of conventional gasoline = 115,500 Btu/gallon
    The lower heating value (LHV) of ethanol = 76,000 Btu/gallon
    Hence it takes 115.5/76 = 1.52 gallons of Ethanol to replace the energy in one gallon of gasoline. These values can be found here.
    Every fuel has two energy values, sometimes called lower and high heating values. The lower value is the energy you can get without condensing the water out of the exhaust. "Condensing furnaces" for your home do just that and can almost recover the higher heating value. Cars cannot use steam in their exhaust; it just goes out the tailpipe.
    For cars, and all internal combustion engines, the lower heating value is the relevant value, yet DOE almost always publishes the higher heating value.
    How much should you pay for E10 and E85?
    If regular gas is $3.00/gallon you should pay
    $2.90 / gallon for E10 (10% ethanol).
    $2.13 / gallon for E85 (85% ethanol).
    If regular gas is $2.00/gallon you should pay
    $1.93 / gallon for E10 (10% ethanol).
    $1.42 / gallon for E85 (85% ethanol).
    Then you will be paying the same amount per mile driven.
    The formula is this: For EX, where X is the percent ethanol
    Ethanol price should = Gasoline price times (100 – X + X/1.52)/100
    Notice that 100 – X is the percent of gas and X/1.52 is the percent of ethanol adjusted down by about 2/3 because it has less energy.
    New Recipe For Gasoline [Ehanol] Helped Drive Up the Price
    NY Times, May 6, 2006, By MATTHEW L. WALD
    WASHINGTON, May 5 — Nine months after Congress passed major energy legislation, one provision affecting gasoline formulas is helping to drive the price of gas up much faster than the rising price of crude oil.
    Ethanol is pricey and energy-poor. Its price is up by about $1.30 a gallon in the last year, in part because of heavy demand for something to replace MTBE. But ethanol has only about two-thirds as much energy.
    And because the new gasoline recipe contains less energy, mileage per gallon is declining.
    On Friday, ... the Energy Policy Act of 2005 ended the requirement that gasoline sold in areas prone to air pollution include an "oxygenate." ... Refiners over most of the country's big gasoline markets, anticipating the rule, have already dropped the chemical MTBE.
    The refiners were not explicitly required to drop MTBE, but virtually all have done so because it has polluted groundwater and exposed them to liability suits. ... But now refiners must replace that ingredient. And they need a substitute that is also high octane, as MTBE is. Refiners have turned in part to ethanol, which is also an oxygenate but not a pollution worry.
    Ethanol costs more than gasoline, and shipping it from the Midwest, is cumbersome and expensive, because it has to go by barge, railroad tank car or tanker truck, rather than pipeline.
    West Texas Intermediate, the American benchmark oil, was up only about 39 cents a gallon last month compared with April 2005, while the wholesale price of gasoline rose about 64 cents over the same period. ... Experts at the Energy Department, the refiners' trade association and elsewhere agree that the changeover from MTBE was a factor, although they differ about the amount. ...
    The oxygenate requirement has been obsolete for years. It was intended to make the fuel mix leaner, reducing air pollution. But that works only on older cars, with carburetors, not in modern vehicles with oxygen sensors and fuel injectors.
  11. derstuka
    San Diego, CA
    BTW....just so you know....I am not telling you not to make the switch, I was just trying to dispel what you claimed the IRL said about ethanol increasing their mileage. By all means go for it if you want to. Wouldn't it be more cool to have a biodiesel VFR though? Ahhhhhh...the smell of french fries wherever you go!
  12. Joey_Dude
    Joey_Dude Member
    North Georgia
    Just wanted to put a thanks there for that informative post Derstuka! Yes, I know I can be quite a geek at times. :nerd:
  13. SLOav8r
    SLOav8r New Member
    Central Coast, CA
    Ethanol is great if you believe in starving this hemisphere. Not to mention the ridiculous amount of FOSSIL fuel consumed during the production. [​IMG]
  14. bladrnr
    bladrnr New Member
    Santa Rosa,CA
    I guess I'll have to wait for battery technology to develop enough and have an electric bike. Big oil just isn't going allow anything but gas to be developed. :bs: Facist Bastards. :bs:
    Somewhere around 2050. :bs: Uh oh,whoops. I'll dead by then. Probably from lung cancer. COUGH,HACK,Wheeeeez. :bs:
    I don't know what to tell about the IRL. They reduced the size of their fuel cell from 30 gal to 22 gal and able to go the same distance. They were using methanol before which was basically jet fuel. Not really like gas though,huh.
  15. bladrnr
    bladrnr New Member
    Santa Rosa,CA
    I think I'd rather use Krispy Kreme oil instead. Mmmm Lard.
  16. cjheap
    cjheap New Member
    Right, The big oil conspriacy.
    Research the Ethanol Scam and get back to us. It is bad for the environment and is only marginally cleaner than gasoline while wasting our drinking water and crop lands.
    And Methanol is nothing like Jet Fuel. Jet fuel is Kerocene while Methanol is alcohol that was once derrived from wood but is now synthetically made from natural gas.
  17. mello dude
    Romania
    No way in hell I'm putting any ethonal in my rides or cars.
    MD
  18. bladrnr
    bladrnr New Member
    Santa Rosa,CA
    What they were using smelled like kerosene which is the same way helicopter fuel smells which they call Jet A fuel. I'm no expert but I definately didn't ask this question to be talked down to. I'm not a mechanic or a fuel expert.You learn by asking questions.There are a lot things you can make fuel out of now with mixing vegtable matter with enzymes.There has to be something else that can work as well as gas. I'm hoping someone can figure it out. Hydrogen isn't it. Hybrid tech isn't it. Ethanol isn't it. Batteries aren't there yet either.
    And if you think big oil and car companies aren't keeping down Alt fuel and energy sources you should wake up. Look what happened to Tucker,The Red Car and the EV-1.
  19. cjheap
    cjheap New Member
    Wow, the conspiracy theories abound.
    I am sorry if you took being provided facts as talking down to you. You can get the same information from a google search.
    And I personally know what Methanol is since I have a degree in chemistry and a graduate degree in envirionmental Biology . I also use it to make Biodiesel in my garage.
    The Oil companies are not keeping alternatives down, they are working hand in hand since they have to cooperate to get the government welfare check.
    As for the EV1, It was a prototype. It never went into production because it was too expensive. They were collected and destroyed after the tests because they were not certified for use after the tests were over. So what makes you think that they could be production vehicles when the LI batteries are not available for large scale production? Or are you suggesting that a glorified golf cart would sell for the $100,000 price tag that they cost to produce?
    red car line is another theory that has been debunked. The line was a scam to get people to support new subdivisions outside of LA and never were profitable. GM had nothing to do with it.
    http://www.1134.org/stan/ul/GM-et-al.html
    You want the solution.
    Drill here now to control our supply
    of liquid fuel. It is not going to change any time soon. It takes 15 years to even get the current fleet changed out to a new year model.
    Alternatives, They do not even cover 1% of our curent energy needs . SO how fast do you think they can ramp up. They are not even able to meet the demand for Windmills now and have a 5 year backlog, that when completed, will double the capacity.
    Corn Ethanol is a waste of energy and resources since it uses almost as much petroleum based fuel to produce as it can deliver.
    Fast track Nukes
    This will allow us to liquefy coal and Natural gas for motor fuels. That can meet our needs for fuel just like it did for the Nazis in WWII when the US cut off their crude supplies.
  20. supertex
    supertex New Member
    WOW. I didn't know I was a member of alternatives fuel anonymous. Thought this was "WONDERFUL BIKES TO RIDE LAND".
