motorcycle grips
Discussion in '1st & 2nd Generation 1983-1989' started by volks6000, Mar 30, 2009.
  1. volks6000
    volks6000 New Member
    Jacksonville , Florida
    hey does anyone have a place to get good grips?? mine are kinda worn :frown: out and have to squeeze the right one because it's starting to slip.
  2. drewl
    drewl Insider
    Virginia Beach, Va
    Pro grips gel
  3. Ghost
    Ghost New Member
    Kernersville, NC
    I have some, that are "supposed" to fit mine, but they dont. they are for a 85-91 honda VFR. is one grip a smaller diameter than the other?
  4. ianjoub
    ianjoub New Member
    Homosassa, FL
    I like the Honda grips. They are about $12/pair.
    One should be a smaller diameter hole for the left side and slightly larger for the right to fit over the throttle tube;)
  5. mello dude
    Romania
    ProGrips 669! your dealer can order
    .:: PROGRIP :: The Race Passion Company ::.
    MD
  6. Ghost
    Ghost New Member
    Kernersville, NC
    OMFG! I am so stupid! I took one out of the package, slipped off my left side, and the rubber was very loose, not crazy, but.... *sigh* if I get home and find out I've had new grips for over a year...
    Ugh, I feel so stupid.
  7. RWB25
    RWB25 New Member
    North Bay, Ontario
    That's ok. It's happens to the best of us too. Other sites may ridicule you for such a move but we're all part of the VFR brotherhood.
    But we promise not to laugh. :joker: .....too hard. :crazy:
  8. RWB25
    RWB25 New Member
    North Bay, Ontario
    MD,
    Is that 699? Or 669?
    I can't find the 669 model Pro Grip's website from the link you posted. :confused:
  9. mello dude
    Romania
    Oops - 699 aka waffle grips. Used 'em for years. Pic in my gallery.
    MD
  10. volks6000
    how do you get to order them from there web site???
  11. mello dude
    Romania
  12. Hootch
    Hootch New Member
    Vancouver, WA
  13. Ghost
    Ghost New Member
    Kernersville, NC
    (facepalm)
    *Insert Typical Engineer Jokes here*
    Yes, I didnt read the instructions. I, for whatever reason, thought "How can you fuck up Handle Grips!?", laughed, and tossed the instructions aside with another chuckle.
    I put on my new grips last night.
    Guess the Grips got the last laugh at me.
  14. RWB25
    RWB25 New Member
    North Bay, Ontario
    As long as no tools were harmed during this production, then all is well.
    Now get out and ride! :thumbsup:
  15. ianjoub
    ianjoub New Member
    Homosassa, FL
    I put new grips on last night as well. I like to leave them for at least 24 hours so the weatherstrip cement can fully cure....
  16. tcarroll
    tcarroll New Member
    Shelburne Falls, MA
  17. RWB25
    RWB25 New Member
    North Bay, Ontario
    MD,
    When you installed your 699's, did you use any adhesive? Or did you just follow the ProGrip instructions and just use soapy water, slide on and let dry for 24 hours?
    And did you just cut your stock grips off? Or did you use some secret ninja move to remove the stock grips intact?
    Just curious.
  18. 300shooter
    300shooter New Member
    armpit of ontario (Windsor)
    To get the grips off, use a small air nozzle,and get air under the grip, it works better on one piece bars where you can block off the other end but you can still get them if you work at it a bit, if you want tot save a couple bucks.
  19. RWB25
    RWB25 New Member
    North Bay, Ontario
    I'm not too concerned about saving the stock grips. I don't need them anymore. I'll give the air a try. If it's a pain, the knife will come out.
    Thanks.
  20. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    yep what drewl said
