My 500 interceptor will run then won't?! Help!
Discussion in '1st & 2nd Generation 1983-1989' started by sanlot17, Apr 7, 2013.
  1. sanlot17
    sanlot17 New Member
    OH-IO
    My 86 500 Interceptor has only 5000 miles. Has new fuel in it. Sat for over a year when I bought it. Tank inside is very clean looking. When it does run it runs ok. Will idle when warmed up. Take it for a mile of two and starts to run out of gas. (Full tank) checked gas cap and free flowing air. Shouldn't be vapor lock? Could the petcock have issues? If I squirt start fluid in air box it will start and eventually start running again? Soon as I go down the road for a few miles it stalls out all over? Any help would be awesome! Thanks!
  2. stewartj239
    stewartj239 Member
    Syracuse, NY
    When it does this, if you stop and turn it off for a minute or two, is it good to go after that for the same duration? I had the exact same issue as described and my problem was that when I put the gas tank back on, I had pinched the fuel line from the tank to the carb. Mine were not OEM, so they were a little longer and I had to shorten them. To me, it sounds like a fueling issue.
  3. sanlot17
    sanlot17 New Member
    OH-IO
    Yes for sure fueling issue. I will check it out.
  4. sanlot17
    sanlot17 New Member
    OH-IO
    Well took off the petcock and tore into it. I found the diaphragm for the vacuum was crinkled. Fixed and runs awesome!
  5. hopit88
    hopit88 New Member
    Cool. Nice to find the easy fixes now and again.
  6. sanlot17
    sanlot17 New Member
    OH-IO
    That's for sure! Hope to get some riding in today. :)
  7. stewartj239
    stewartj239 Member
    Syracuse, NY
    That's great news. Easy fixes are always the best. Let us know how the ride goes.
