My 5th gen VFR is cutting out when warm - operating temprature.
Discussion in '5th Generation 1998-2001' started by goflynn, May 1, 2015.
  1. goflynn
    goflynn New Member
    It feel like this is either an electrical connection impacted at temperature or some main controller. I don't even know where to start. Anyone got any ideas?
    Start bike up cold: it behaves normally.
    Allow bike to warm up to operating temperature
    -Neutral indicator light starts to flicker and buzz/crackle and goes off. ( engine cuts out if on side stand)
    -Rev counter drops to zero with engine running
    -Applying throttle, engine splutters and does not rev smoothly.
    Thanks,
    ~g
  2. rjgti
    rjgti New Member
    regina sk
    r\r or stator
  3. goflynn
    goflynn New Member
    Rjgti , thanks for the suggestion, why those?
    I just replaced melted connector harness and upgraded some wiring and now the electrical charging system seems strong. The Stator and RR passed all the bench tests and stator passed tests under load @5000rpm. I have a Voltmeter installed on the side of the bike and its showing reasonably consonant charge as the bike heats up.
  4. rjgti
    rjgti New Member
    regina sk
    OK then check coils
  5. Scubalong
    How many miles on the bike and what is the maintenance record :noidea:
    Fuel injectors clean? Coil, spark....Bad fuel....?
    I wwould go over all the keys items to narrow down the guess work before digging deep in to the electrical.
  6. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    How old is the battery? A couple years ago, mine would start and run fine, but when slowing for a stop it would die. Would refire but had to keep throttle to it. A new battery fixed it.
  7. Terry Smith
    Definitely electrical, I'd suggest maybe a bad ground connection given the neutral/rev counter behaviour. Might pay to go through all the connector blocks and make sure they are cleaned and tight.
  8. goflynn
    goflynn New Member
    Sorry for the late responses. The bike has 45K . The battery is over 2 years old but tested ok . ( i just went through an full RR/Stator/ battery test). The battery could be upgraded but i am not that keen to start upgrading different components.
    Cadbury, Where specifically are the connector blocks on a 5th Gen VFR? I will check them,
    rjgti : "OK then check coils"
    Are coils apt to fail when hot? The bike seems fine when cold.
    Scubalong, "Fuel injectors clean? Coil, spark....Bad fuel....? "
    I'm not sure why any of these would surface as issues when the bike is warmed up. I would expect them to cause the same issues hot or cold, right?
  9. Terry Smith
    There's no one block I would check, but the wiring harness has multiple connectors that you could pull apart, check they are clean (contact cleaner) and not corroded, then reinstall. Given the symptoms I'd be starting at the front of the bike with the fairing off and checking where the harness connects to the handlebar controls and instruments first.
