My DIY rack and panniers. Pics and details.
Discussion in '3rd & 4th Generation 1990-1997' started by redux, Jan 23, 2009.
  1. redux
    redux New Member
    I recently sold my car and the tractor is now my main form of transportation, thus I needed to increase its cargo capacity. Being a pretty odd and old bike (1996 Honda VFR750) the only commercial option I saw were the Givi cases and mounts. Even the most basic set up would cost me over $600. So I decided to make my own.
    Making and mounting panniers for under $50, little to no tools, and almost zero fabrication experience.
    First, I set out to look for the actual boxes. After much research and indecision at various stores I settled for US Army ammunition cans. The 11X16X5 in 60mm mortar ones. Why ammo cans?
    * Cheap at $10 per box
    * Airtight and durable
    * Come in a variety of shapes and sizes
    * Many places to get replacements
    So here are the said cans.
    I then continued to see how they would fit on the VFR by using bungee cords.
    Satisfied with the looks I now needed a sturdier replacement for the bungee cords. Thus I pulled off the plastics and was surprised to see two holes in the frame already pre-drilled and threaded.
    Obviously, the plastics of the bike would not allow me to attach the panniers directly to these holes, so I decided to make L -shaped brackets from aluminum (aluminium). Scroll down to the test fitment part if you're impatient.
    I went to my local hardware store, in this case, ACE Hardware and picked up some aluminum square tubing, L - shaped door brackets, and nuts and bolts to hold everything together and WASHERS. Lots and lots of washers. I can not stress the importance of those enough when putting together anything that requires tension.
    I chose aliminum vs steel because it was cheaper, much lighter, and a lot easier to cut and drill. Steel would be weldable and stronger.
    Using a folded sticky note as my 45 degree angle I started making the actual rack. The pictures below are out of order, but the point is to test fit as many times are you can.
    A few things happened on the way. First, the plastics would not go on over the brakets, so I ended up having to cut out bits and pieces of it to make it fit. The whole thing looked crooked and did not line up properly. Turns out - the plastics were not on straight and the previous owner that installed the turn signals and tail light also but it on croocked.
    I tested the whole thing by trying to break of the racks with my weight, but they worked out just fine.
    To attach the ammo boxes, I simply drilled holes and used very large washers along with rubber ones to spread the stress.
    They were then bolted to the bike.
    Here is the final product. I added a flex-bar to prevent the cans from bending inward .The front is supported by the passeneger pegs.
  2. Knife
    Knife Member
    Downingtown, PA 19335
    Tres cool!
  3. reg71
    Sikeston, MO
    I like it man. Better then GIVI in my opinion. Way more unique. Now you can cover them with bumper stickers from all the places you visit on the bike. Hell if I hadn't already bought RK luggage I might do something like that on my own! Cheap and functional is right up my alley...
  4. Nitrousva
    Nitrousva New Member
    Richmond
    Fugly bags, but man, what a great job! I'm impressed, I did notice in one picture that the wires to the computer may rub on one of the brackets.
    I might steal that idea, and put some on my DT175, it's a Yamaha enduro.
    Good job
    Robert
  5. Yonan
    Yonan New Member
    TURLOCK, CA
    Very cool, nice job.........would look great if you painted the rest of the bike Army green.
  6. dale-j
    dale-j New Member
    British Columbia, Canada
    Look out Touratech...redux is chasing your market share ;)
    Simple, durable, effective, not too wide and oh yeah... CHEAP! Probably even crash proof.
    Bet I could fit some of these in similar fashion on my FZR1000 - seeing as Givi doesn't offer a bag option.
  7. Necro_99
    Necro_99 New Member
    I had written a friendly critique all written up... then I noticed that you addressed the the things I was commenting on... namely the rear cross-bar and the connecting the boxes to the passenger pegs. So... Good job! :)
  8. drewl
    drewl Insider
    Virginia Beach, Va
    So a month later, how have they held up?
  9. redux
    redux New Member
    I actually had the misfortune of crash testing the set-up. Dropped the bike trying to park on under-funded streets.
    They held up just fine and acted as frame sliders. Nothing was bent, just some scratches. The seals work well - no water in them even in the pouring rain.
    I am trying to make a quick-release mechanism as having to under 4 bolts every time I am taking on a passenger is annoying.
  10. FearIsGood
    FearIsGood New Member
    Love it! Has some serious attitude. I am definitely stealing this idea if I ever need more luggage than my top case.
  11. rmr52275
    rmr52275 New Member
    Mohawk Valley, NY
    You think they could be mounted to accommodate a pillion? Nice job!
    rick
  12. pjm204
    pjm204 New Member
    NJ
    nice work, my only criticism is that you should have gone with the 20mm ammo cans so they could have been loaded from the top instead of from the front.
  13. kd4ysi
    kd4ysi New Member
    Columbia, South Carolina, United States
    nice work but wouldnt hold enough for me ill stay with givi
  14. great white
    great white New Member
    Creative, but not my cup o' tea....
  15. proverbio
    proverbio New Member
    San Gabriel Valley, CA
    Now, all you need is a mount for your red mountain bike.
  16. carbon
    carbon New Member
    Hi, I think I saw this on another forum somewhere, and I think you stated that you no longer consider this rig safe? I'm just curious. Is that still the situation? I was going to attempt to construct a similar design, but instead of using those door frame L brackets, I was going to have a buddy weld all of my seams. I was also considering some sort of tube frame design.. My main interest would be in building a luggage rack for the rear. Something clean and discreet, which does not exist from what I've found for 96 vfrs
  17. safetypro10
    safetypro10 New Member
    Dallas, TX
    Homemade luggage
    Here's what I learned doing my own adaptation of Krausers from an 80's BMW.
    Good mounting points on subframe. Another good point is the bolt hole on each passenger footpeg.
    I used 1/8" X 1" SS strapping from a hardware store. Tough, bends grudgingly and drills, but hard and resilient.
    On your removability question, try dzus type fasteners. 1/2 turn on their gone.
    Like the ammo cans, but you do need olive drab paintjob to go with it.
    Larry
  18. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    I want to see the wicker basket modded to the front cowl!
  19. deepdish
    deepdish Banned
    :biggrin::biggrin:looks great...:rolleyes: did you reupholster the seat as well??? I like the matching ductape stripes on seat very cool....:wink: i have some old metal trashcans i wonder how that would work??? definetly help out with the storage issue...:thumbsup::thumbsup:
