need 2 no best tool ?
Discussion in 'Mechanics Garage' started by squirrelman, Oct 17, 2018.
  1. squirrelman
    what tool is best-designed for removing these connectors from the plug ?
    obviously i managed, but it was a struggle.
    recently converted an '86 VFR to run with Yamaha Radian r/r, seems OK.
  2. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    I have a small unfolded cotter pin that I jam in there with a pair of needle nose pliers. Works great. It's one of several weird but useful bits I keep stuck to a big magnet in the garage (that way it never gets lost). I've rewired two motorcycles with custom looms for do-it-yourself fuel injection projects.
  3. squirrelman
    OK, that works, but what's the Proper Tool, not an improvised make-do.
  4. GreginDenver
    Denver, Colorado
  5. fink
    fink Member
    Jewellers screwdriver flat blade if you have one , or alternately the linked tools.
    Secret is to push the connector forward so the tang isn’t resting on the plastic housing. Then push down on tang.
    Longerfellow and squirrelman like this.
  6. fink
    fink Member
  7. Doug7200
    Doug7200 New Member
    El Segundo or Gardnerville!!!
