Need a new OEM chain
Discussion in 'Mechanics Garage' started by rmse17, Mar 12, 2016.
  1. rmse17
    rmse17 New Member
    Hi everyone, I need to put my 2006 Interceptor into a shop to get the chain and sprockets replaced, but I want to buy the parts and just bring them to the mechanic. I am looking at bikebandit at the OEM components, but for the chain, I see two different ones listed:
    1. - CHAIN SET, DRIVE
    (DID50 112-120L) (DAIDO) (STANDARD LINK 110L),AC 2AC 06405-MZ1-P01 242.43
    and
    2. - *40540-MZ1-317
    (RK50-112-120L) (RK EXCEL) (STANDARD LINK 110L),AC 2AC 40540-MZ1-317 444.91
    I am assuming those are two different chains that come from OEM, but what is the difference? Should I just get more expensive and assume it is better? I couldn't find comparison based on part numbers.
    Thanks for your help!
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    If it was me I'd by the DID, but I wouldn't buy OEM. I'd buy from an aftermarket vendor. You should be able to pick up a good DID chain for around $125-$140.
  3. northwood
    northwood New Member
    Bay Area, CA
    Yup, aftermarket. Just bought a set from sprocketcenter.com They have an OEM option for chain. Much cheaper. I went with the 17 x 45 and DID 520 X-ring. Larger sprockets are easier on the chain.
  4. sunofwolf
    sunofwolf New Member
    P1010261.jpg IMGP0354.jpg 17-43 would have been better, it may be to low, I am running a 16-45 and that is close to perfect, next time I go with stock gearing 16-43,
  5. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Yup .... agreed!
    I replaced the chain on my last VFR with the DID 530 VX Pro-Street X-Ring Chain (2002 6th Gen)
    I went with stock gearing. I'm all highspeed / highway as I commute about 160-170km's round trip every day from the country into the outskirts of the big city.
  6. northwood
    Bay Area, CA
    I went with the 17-45 because it is +1.5% on speed and -1.5% on torque from stock, where as the 17-43 is +6.3% on speed and -6.3% on torque. I didn't want to lose out on 6.3% torque but I wanted the rpm's a smidge lower. A 16-45 is -4.4% on speed and +4.4% on torque from stock. I have a track bike for going fast. I used this website as a reference:
    http://www.sprocketcalculator.com/
  7. sunofwolf
    that speed chart is wrong on a 2006 vfr
  8. northwood
    Bay Area, CA
    Doesn't matter what bike it is. It just compares stock sprocket combo to optional sprocket combinations. If you are unsure of it, you could look up diamond chains website or calculate sprocket ratios. This isn't rocket science. Please, do explain how it does not relate to a VFR.
  9. V4toTour
    V4toTour New Member
    OEM sprockets are hella expensive. You can grab OEM sized JT Sprockets off amazon for like half the price Honda wants. Whatever chain you want.
    You can find your bike's stock gearing and part #'s here.
    http://www.jtsprockets.com/catalogue
  10. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    A quick note ... the OEM front sprocket is worth the money if you're staying stock.
    It has a rubber coated surface on the sides that dampen it and reduce vibrations. It's noticeable.
  11. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    That's debatable, I never noticed any difference between stock and aftermarket countershaft sprocket. Some notice a difference, and some don't. Not worth the price difference to me, but I'm a cheapskate. :beguiled:
  12. V4toTour
    V4toTour New Member
    Yeah, I didn't notice the change. But then again between aftermarket exhaust and wind noise, who knows...... :noidea:
  13. 34468 Randy
    Funny how some will feel vibration and some won't. My son does not feel the effects of a missing wheel weight on the front of his civic yet I feel like the car is shaking apart.
    The last several chains and sprockets I have gotten for mine have been from the Sprocket Center. I have been using DID with the X ring. OEM specs. I will let everyone else consume far to much time and effort getting miniscule performance improvements by using sometbing other than what was designed for the bike. Maybe next time I will follow Jeff's lead and go back to OEM front sprocket and see if I notice the difference. But as it is, I am not noticing anything that is bothersome.
  14. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I noticed a huge difference ... but I'm always listening and feeling for changes in the bike at all times and am sensitive to it.
    Maybe it's because I spend so much time in the saddle putting 20,000+ km's per year on a bike? (I want to say last year did closer to 30K??)
  15. squirrelman
    I agree with Jeff that the rubber-damped OEM front sprocket is worth the extra $$ cuz it's quieter, with less vibration.
  16. sunofwolf
    I would say the rubber has to make a difference
  17. 34468 Randy
    Someone should have told your daddy that.
  18. V4toTour
    V4toTour New Member
  19. JCIV
    JCIV New Member
    Atascadero, CA
    This thread was just what I was looking for! Just ordered a DID kit from sprocketcenter. Thanks :)
  20. James Bond
    James Bond Member
    Dixie
    This is very good advice. Been there, done that.
