Need help with getting into bike racing
Discussion in 'Anything Goes' started by matt1986vf500f, Feb 17, 2009.
  1. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    hey guys i would like to start racing bikes as a hobbie, but i need help getting started.
  2. betarace
    betarace New Member
    Middleburg, VA
  3. matt1986vf500f
    what about rules and guide lines for the bike?
  4. betarace
    betarace New Member
    Middleburg, VA
    both clubs have online manuals on the links I provided. WERA has a vintage class (also in the rule book) but the general rule is safety wire everything, no glass/mirrors/reflectors, full catch pans, no coolant (water).
    have you ever ridden on the track before? if so, racing is probably not the place to start, would advise a track school such as California Superbike School, Kevin Schwantz Superbike School, Jamie James, Cornerspeed, Ed Bargy or one of the many schools out there.
  5. matt1986vf500f
    no this would be the first time on the track with a bike, i wont be running my 86 vf500, i will most likely be purchasing a f4i or r6 for track dutie.
  6. betarace
    betarace New Member
    Middleburg, VA
    OK, given that, would
    1) go to one of the track schools I mentioned, here is a more comprehensive listing
    Sportbike Motorcycle Riding Schools - Motorcycle USA
    2) join a track day club (usually a nominal fee) such as:
    NESBA : Northeast Sports Bike Association
    Sportbike Track Time - Get on the right track !! Toll Free #888-390-4020
    3) do a few days - I see you are in Georgia, so NESBA is prob your best bet, you can do Road Atlanta, Carolina Motorsports Park and Barber
    4) join WERA novice program
  7. TOE CUTTER
    size
    Raced with a friend for years and he felt he needed to start out on big bore machines and after two years worked down to 500 for the fun and lap times. Turned best lap times on a 500.Cost was much less and skill really came into play at that level.
  8. squirrelman
    Can you afford $800-$1200 (minimum) per weekend??
    Have full 100% total comprehensive Medical insurance??
    Woudn't winge if your whole bike went up in flames??
    Can afford to take time off work while your ankle heals??
    THEN go 4 it!!
  9. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    $800-$1200 on a weekend??? What do you do stay at the Ritz? ;)
    The rule book should answer all your questions. Safety wire drain plug, brake bolts, axels and everything else. Remove center and side stands. Put in better front springs and fluid, better rear shock and get the softest tires you can. One or two piece leather suit and last Snell/Dot motorcycle helmet. Number plates and your ready to roll. You may have to remove turn signals also. Locktite Every screw and bolt you can. Sooner or later it will vibrate loose.
    Most racing sanctions make novices go thru rider/racer school at the race weekend for most grassroots type racing. MOST of all, once you are on the track forget about going fast! Main thing to learn is how to take corners. Then adjust to the corners on the track with your brake points and acceleration coming out of a corner (around the apex). There are only three types of corners so learn them. 1-going on to a straight, 2-coming off of a straight and 3-corner between corners. Keep the ball of your feet on the pegs (mostly) and support your weight with your legs an upper torso. In other words OFF the seat, except straights may be. Lower CG.
    The speed will come with smoothness and refinement of your riding. Don't worry about it. When you go out to practice that's what you do. You don't race, you practice your lines. Find a good racer, someone who knows the track and follow them in practice. It helps when just learning. One exception to that. You may also follow them off the track all the way to the wreck!
    But MOST of all have FUN, ask anybody for help, most will be glad to help a novice.
    GOOD LUCK
    Just found the NESBA manual. Read it, it will give you an idea of what to expect.
    http://www.nesba.com/Info/Downloads/manual.pdf
  10. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Many NESBA track day riders also race. They would be very helpful in person to answer questions while you are getting used to the track.
    BZ
  11. betarace
    betarace New Member
    Middleburg, VA
    you may be well advised to pop in (free) at a NESBA track day to get a feel of the tech inspection, riders meeting ask Q/A etc
    here are the Road Atlanta dates, which I presume are near you
    NESBA : Track Detail
  12. tbone
    tbone New Member
    Omaha, NE
    I would try a few track days first. The sport is very addicting and VERY EXPENSIVE. I did it for about 5 years and would work all year just so I could go racing on the weekends during the summer. Unless you have LOTS of disposable income I would shoot for few track days a year. Things add up very fast, especially if you crash alot. Although I don't regret racing I wish someone would have told me about the cost up front. After I stopped racing it probably took me 3 years to get out of dept from racing.
    Before you even start racing you will need:
    Leathers
    Boots
    Gloves
    Back protector
    Helmet
    Your bike will need:
    Tires
    Bodywork
    Stands
    Brake Lines
    Brake Pads
    Gearing
    Lap Timer
    Tools
    A weekend of racing will cost you:
    $200-$500 on entry fees
    $300-$500 on tires
    $200-$1,500 on food, travel, gas, lodging
    A crash will cost you:
    $1 to $???,???,???
  13. NorcalBoy
    How do you make a small fortune?.....take a big fortune and go racing.
  14. 02 VFR Rider
    02 VFR Rider New Member
    Don't let these guys scare you off of racing.
    1) gear got to have it and better be good. don't be cheap.
    2) tires BS used same tires for whole weekend your not a pro dont sweat that right now.
    ( if you get that far let me know i'll send you link to good track tires for cheap )
    3) never took a track day or class before going to track. Track will ( should not to familar with WERA they took my ama licence when i did a few wera races ) have a class that is required to take to get licence ( you must not crash in licence race to get it so just take it easy plenty of time for crashing later ) they will teach you the track lines and everything else you will need to know to get you started. I did penguin roadracing school at loudon N.H. = N.H.I.S.
    hardest thing was safety wiring a 90 gixxer every bolt almost had oil passage under it LOL
    you don't need to run a full season, get your licence then you can run open practice usally the friday before a race weekend. just cost for practice and licence in hand is all you need no race entry needed and better then track day cause you can run your own speed and fellow racers will provide all the help you can stand and more to get you going faster.
    cost well $ 25,000.00 - 35,000.00 a year with limited sponsorship for 2 classes 750 supersport and unlimited GP for full season run. not including price of camper.
    IE gass food bike stuff entrance fees so on and 1990's so prob more today.
    pm me if you want anymore info.
  15. matt1986vf500f
    thanks to all of you guys for the help, ive found the perfect bike for this, a 2005 gsxr 600, so ill be leaving in about a hour to get it, and then i can start all the safety wiring, i am having a hard time with that every bolt needs to be wired????
  16. betarace
    betarace New Member
    Middleburg, VA
  17. TOE CUTTER
    Bits
    Buy 30 or more bits to start.Nothing worse than running out at 10 oclock at night.You may break one or two.Dozen.
  18. NorcalBoy
    If you have access, or can gain access to a drill press, buy a nut and bolt drilling jig...it makes the drilling process a little bit less painless. The bummer is having to dis-assemble the nuts and bolts to drill them, this probably isn't a big deal as you should inspect and torque these things prior to hitting the track anyway.
    Nuts POSSE SAFETY WIRE NUT DRILL JIG
    Bolts POSSE SAFETY WIRE METRIC BOLT DRILL JIG
  19. GreyVF750F
    GreyVF750F Member
    Not every bolt/nut has to be safety wired. The NESBA manual on page 20-21 describes what they want. Beginner class they don't require much. http://www.nesba.com/Info/Downloads/manual.pdf
    Check with the racing organization your going to be racing in. Find out now instead of at the track.
    Great safety wire links, by the way.
  20. 02 VFR Rider
    my bike was a 90 gixxer and was oil cooled not water cooled so had more to wire then what you will have w/ water cooled bike.
    buy buy alot of drill bits my friend you will need them.
    best bet is to find someone who has same bike and you will see they will be more then happy to help you out.
    I found that the people at the track will always be there to help anyone who needs it.
    racers are the best and when I raced and broke something they would take the part off their bike while I was getting into my leathers and put the part on my bike so I could make the race. Kudos to them all.
