need help with headlight modulator
Discussion in '6th Generation 2002-2013' started by tomih84d, Dec 15, 2009.
  1. tomih84d
    tomih84d New Member
    manchester IA
    apparently i have a headlight modulator on my 04 found this out from vfr world. Well now it has a problem, thought the lower right headlight has burned out but then magically it fixed itself.... some short reading later there is a wire that comes loose on the back side of the modulator and causes this ( now the proclem) what does the modulator look like, is there a common place to mount these, what do they look like? not a clue on any of this yet but im sure i will find out. I know it has to be somewhere between the switch and the lights but i was hoping for some input on this before i disassemble the entire front end of the bike looking for it.
    Is this a common problem for the modulator or just a chance happening?
