need help
Discussion in 'Mechanics Garage' started by falcon_1234us, May 11, 2009.
  1. falcon_1234us
    falcon_1234us New Member
    here is what i got an 85 700 intercepter been working on it for a month cant get it to run. think i have a short but cant find it. put the fuel pump and realy on it cant get it to kick in. so if i unhook it all and run it gravity feed will it work or will that short still cuz me trouble? i have done the carbs twice. i got new plugs and wires. just cant get it gas could the fuel rale get junk and not let gas to all 4 carbs. im lost and need help.
  2. TOE CUTTER
    Fuel
    I would suggest unplugging the fuel pump and jumping it off the battery to charge the fuel system to ensure you are getting fuel delivery.:thumbsup: And yes it will gravity feed but would run fuel pump myself.
  3. falcon_1234us
    ok thanks i think there is junk in the carb blocking it can run off starting fluid but no gas when gravity feed ing could the fuel rail be pluged up or what could it be cant get fual pump to work.
  4. TOE CUTTER
    bugs
    Had a rare one about thirteen years ago where fuel system was open and beetles got in lines. Guts were gone but wings and shells got in screens and would plug up after a short ride and had to get really pissed off to blow the whole thing apart to figure it out.Anger but a lesson learned.:eek:
  5. falcon_1234us
    ok thanks will work on this weekend any more trouble will be back on to try to get help.
  6. squirrelman
    jump the fuel pump relay with a wire, open one float bowl drain screw and wait for drippage to confirm fuel flow, close screw.......then start your bike.
    find which circuit has the short by removing all fuses and adding one at a time
  7. falcon_1234us
    what if it dont jump but does have power to it cuz it wont jump im vary loost on this one.
  8. masonv45
    masonv45 New Member
    If you provide power directly to the pump and it works - but jumping the relay does not, then you may have a bad relay.
    Also, before troubleshooting, remove, clean and reconnect all related electrical harness connections, power, and ground points for the circuit you're working on.
  9. falcon_1234us
    did all new relay and pump and everything i think there is a short works sometimes and not other times when jump it
  10. squirrelman
    If there is a short you will have a blown fuse, so which circuit is it?
    The pump is not really needed for at-home testing cuz you can bottle-feed fuel directly into fuel line to carbs......
