Need help
Discussion in 'Mechanics Garage' started by twoulds, Aug 20, 2018.
  1. twoulds
    twoulds New Member
    Where does this hose go to, or should it be capped? [​IMG]
  2. reg71
    Sikeston, MO
    doesn't that connect to airbox?
  3. twoulds
    twoulds New Member
    There is a different one on the right side coming from the rear air box that connects to the metal air pan but I don’t know where the little one from the air joining tubes in the carburetor goes
  4. twoulds
    twoulds New Member
    86 500 interceptor
  5. twoulds
    twoulds New Member
    [​IMG] found this but it doesn’t show me where that tube connects to and I can’t find anywhere where it connects should this be capped?
    Non- Cali bikes just vent to atmosphere. Point it down with a long enough tube so nothing can get in.
  7. twoulds
    twoulds New Member
    So we’re thinking it’s just a vent tube?
    The 2 green tubes are your fuel, right? (86 500 gravity fed fuel lines split into 2 before the carbs. 84 - 85 feed from the pump to the left most carb) That leaves vent and vacuum, and those are not vacuum lines.
  9. squirrelman
    Not a good idea to remove the airbox base from the carb set, and you accomplished nothing by doing so. :confused:
    +1. Quickest way to crack your brittle fuel and air crossover tubes and/or make the old o-rings leak.
  11. twoulds
    twoulds New Member
    Well good sirs also the only way to replace the fuel lines cuz you can’t get to the left side clamp without taking it off. Which is what I was also doing. But thanks for the tip .
    We aren't trying to bust your balls, but that's the way you CHOSE to do it. You remove the carbs with the plenum attached to accomplish it if needed. The plenum should only be removed (after removing the carb assy from the bike) if the carbs need to be separated, like when you have to replace cracked fuel tubes and bad o-rings.
    Here is the same vent hose, but this is a 86 VFR700F (virtually the same set-up). There is even a little bracket on the slide cap that keeps the vent pointed down.
  14. twoulds
    twoulds New Member
    I know you’re not trying to bust my balls just seem like lotta unnecessary work to remove the whole carb assembly from the motor and then remove the pan from the carb on the bench when I could just remove the pan from the carb in place.
  15. twoulds
    twoulds New Member
    Thank you sir great help I appreciate it very much.
    Unfortunately it's what working on V4s entails sometimes. You dont have to then remove the pan, the hoses are accessible when it is simply turned over. That's just not a shortcut that's a good idea when everything is 33 years old and you are putting stress on it. It's not just what I think could happen, it's the exact thing I've seen happen many, many times. Hopefully it is all good.
