need help
Discussion in '3rd & 4th Generation 1990-1997' started by VfrGuy96, Oct 9, 2019.
  1. VfrGuy96
    VfrGuy96 New Member
    hello everyone I have a question I'm trying to get answered. my bike used to crank up about 3 months ago just fine. I tried to crank it yesterday and all the starter does is just spin and it sounds like its not engaging the starter clutch at all. any help would be greatly appreciated.
  2. upwinger
    upwinger New Member
    Behind The Redwood Curtain
    Battery is probably to weak to start it
    Sent from my Pixel 3 using Tapatalk
  3. VfrGuy96
    VfrGuy96 New Member
    so you think its the battery and not the starter solenoid or should I just replace both since I think the battery is old anyway from sitting too long
  4. upwinger
    upwinger New Member
    Try to jump start it with another battery before you buy anything. Most likely just the battery imho
  5. VfrGuy96
    VfrGuy96 New Member
    Alright I appreciate the feedback will try to jump start with a battery and will come back once I do it and let you know how things went have a great day/night
  6. bk94si
    bk94si Member
    If you are jumping from a car, leave the car not running.
  7. fink
    fink Member
    Why not make a video of it then post it up with your question. That way we are all working from the same hymn sheet and not trying to second guess. You get a lot of it on FB groups, folk trying to describe the above and it turns out its actually the starter relay dropping in and out as opposed to the starter spinning.
    Better to put the battery on charge overnight.
  8. VfrGuy96
    VfrGuy96 New Member
    ill post a video tomorrow since I just got home from work and I tried to jump it and noticed my start button isn't working now either so I have to bridge to starter solenoid and all that does is spin my starter but will have more updates tomorrow after posting a video
    fink likes this.
  9. squirrelman
    lean the bike way way over on the right side to get oil to the starter clutch and try again.
