Need parts # help after lowside
Discussion in 'Mechanics Garage' started by Wxduff, Nov 15, 2019.
  1. Wxduff
    Wxduff New Member
  2. mello dude
    mello dude Member
    Check the fische at Partzilla.com
  3. Allyance
    Allyance Insider
    East Bay, California
    I believe that shifter is part of Quickshifter option, because of linkage tab on bottom ( I have the same set up). Don’t know if you can buy separately. Maybe you can drill out the spot where the peg was and put in a bolt with a rubber boot as a temporary fix.
    Here is the stock shifter:
  4. mello dude
    mello dude Member
    It took me awhile to find the thing as a guessing game, (OK where the effe is that?) It's under pedals...
    # 24701-MCW-D60
  5. Allyance
    Allyance Insider
    Mello Dude, I am afraid that part number is for the stock pedal I show above. Here is a picture of the Quickshifter parts:
    Since this is sold as a complete kit for the VFR only, I doubt you will find just the pedal which has part of the linkage as well. If I had the same problem as the OP, I would find a used stock shifter for as little as possible, and use that temporarily. Then I would find a friendly machine shop that could repair your damaged pedal. This is not a cheap kit, well worth doing the job right.
  6. Allyance
    Allyance Insider
    Years ago I had a set of lowering pegs made by a fellow named Larry at "Busy Little Shop" in the Sacramento area. They were very well made CNC milled aluminum. His email address is netter2@comcast.net. I was hoping he would make them for the 8th gen, but he couldn't get ahold of a bike to use design them. Great guy, heavy into racing, hope he can help you.
  7. mello dude
    mello dude Member
    Got it....thx
  8. Allyance
    Allyance Insider
    Looks like you are very new member, normally members have replied how they fixed their problem when solutions were offered. How did you make out with your quest for a new shift pedal? Your answer could help others.
  9. Wxduff
    Wxduff New Member
    I've worked an average of 80 hours a week the last two weeks so no movement yet. I didn't realize this bike had the quickshifter to be honest, I know it's an aftermarket add on. Kind of annoyed that the peg sheared off now.
    Does anyone have parts numbers for the two damaged pieces of fairing?
  10. 2027Matt
    2027Matt New Member
    Garfield Heights, Ohio
    You should get some frame sliders. If you low side like that again you will have zero damage.
  11. Allyance
    Allyance Insider
    Thanks for getting back to us, fixing your shift lever is the most economical solution. A good machine shop can mill both sides so that they are parallel. Then drill and tap a new hole where to old peg was. Get a stainless bolt and locknut to take the place of the old peg. Get a replacement rubber boot unless you able find the old one. Slide the boot onto the bolt and screw into lever with some threads sticking out on the back, use locknut to secure.
  12. mello dude
    mello dude Member
    Agree with that, mbe some kind of stainless shoulder bolt or possibly a Allen screw bolt/washer/tube or standoff piece + rubber boot combination could work out.
