Need some side stand insights..
Discussion in '5th Generation 1998-2001' started by vbl, Apr 2, 2009.
  1. vbl
    vbl New Member
    Hi guys -
    Last fall my bike was hit while parked on the street and it bent the side stand all to hell.
    When installing a new one I noticed that the actual stand wasnt nesting 100% snug in the recess where it bolts in (it slides laterally between the holes).
    Is there a washer or space piece that I might've missed? I'll try to add pictures when I can get over to the garage where it's parked. The steel tabs might've been bent a little too, but I don't know for sure.
    In the meantime, anyone who has done a side stand replacement and can offer help is welcome to advise. Thank you!
  2. KC-10 FE
    KC-10 FE New Member
    I don't quite know the answer you're looking for since I don't see what you're seeing. That said, here's the best solution for your problem.
    http://store.ridenow.com/fiche_sect...ry=Motorcycles&make=Honda&year=2000&fveh=3961
    Since this is in the 5th Gen section, I'm assuming your bike is a 98-01. Follow the choices to your year & model, then look at the section titled "STAND". Look at the parts fiche & then look at your bike. The bike should have the same number of parts the parts fiche pic does.
    KC-10 FE out...
    :plane: :usa2:
  3. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    All the sidestands I've seen have a little play in them, including the 5th gen's, so they will 'flex' in & out a little on the mount.
  4. vbl
    vbl New Member
    That's encouraging. I was wondering if the tabs themselves had gotten bent away from each other a little and was debating hammering on one to move them closer together and have the stand fit more snugly.
  5. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    I just checked my '99 and it has 1/2"-3/4" movement in it.
