New Brake pads grinding... normal?
Discussion in 'General VFR Discussions' started by Sarli, Aug 15, 2017.
  1. Sarli
    Sarli New Member
    MA
    2003 VTEC, I just changed the front brake pads myself. It seems to stop fine, but the front wheel is not spinning freely -- the rotors are scraping the new pads. I can spin it by hand and hear/feel the friction. Yes, I used the shop manual to do it, and pushing those 3 pistons back was hard.
    ***Is that normal? expected? ***
    Your experience is welcome, please.
    (No, I'll not add WD40 to fix the friction issue, as my 8year old suggested.)
  2. ksoholm
    ksoholm New Member
    Have the calipers ever been rebuilt? Could be time; pistons and seals lead a very brutal life.
    Some light friction is normal; pads will touch very slightly.
    Best,
    Kristian
  3. Terry Smith
    You should also check that the sliding pins that the calipers mount on are suitably slidey, if not the calipers will have a harder time aligning nicely with the disc.
    Allyance likes this.
  4. fink
    fink Member
    I'd go with Terry on the freely moving sliders. As a lot of diy stuff I've seen had had them packed up with grease to the extent they can't move freely.
  5. skimad4x4
    France
    French Alps & London
    +1 - Sounds like the pads are not sliding back smoothly within the calliper - sorry remove pads, clean thoroughly the calliper with brake cleaner ensure the pins holding the pads allow the pads to slide along.
    A more unlikely issue is crap has built up in the bobbins and preventing the disc float - see this video..
    Let us know how you get on.
    SkiMad
