New in town. with an 85 500
Discussion in 'New Riders' started by rickjames, May 13, 2012.
  1. rickjames
    rickjames New Member
    PA
    So i just grabbed an 85 vf 500f on the cheap with only 14k on the clock. Other than checking the valve clearance and other standard maintenance what should i be looking out for mechanically. Oh, the tach is the only thing that doesn't work could this just be a bad connection or stepper motor.
  2. FoothillRyder
    FoothillRyder New Member
    Sierra Foothills
    Welcome lad; but :worthless:
    I'm sure the answers will all be forthcoming. The baby 'ceptor is an all time favorite of mine, although I've never owned one. Color me jealous.
    :cool:
  3. Apittslife
    Apittslife New Member
    Clarksville, Indiana
    :welcome:
    As for the Tach, This is what I did to get mine to work: Remove the Upper fairing & unbolt the Cluster assy from the bike. Then unscrew the connections for the Tach, one at a tyme & clean the connectors. Then use Dy-electric grease & reconnect. Also use dy-electric grease at the main connector for the cluster.
    Good-Luck
  4. rickjames
    PA
    Thanks pittslife ill crack that fairing open this weekend once i get the valve train adjusted.
  5. squirrelman
    I've heard the seats can develop seriously bad cracks......:hss:
  6. squirrelman
    You're aware that some posters say dielectric grease is non-conductive and shouldn't be used as it blocks current flow ????:potstir:
  7. rickjames
    PA
    I've lurked enough around here, and correct me if I am wrong but you have some strange bias against the old 500s. xp
  8. Apittslife
    Then They should continue to refrian from using it.
    I started using it back when I was trying to keep the smoke in Lucas wiring, It did pretty well Concidering what I was working with / on.
    Since it sounds like Metric bikes have simular issues, Dy-electric grease is what I used on My Bike, with a positive result so far.
  9. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    Dielectric grease IS an insulator, preventing electrical flow. However, if your connections are clean and tight, packing them full of dielectric grease serves to basically seal all of our wonderfully unsealed connectors from mother Honda, and also prevents most corrosion. Clean and tight are the important points though, you can skip the grease if it makes you uncomfortable
  10. Apittslife
    You have to understand that Squirrley HATES! 1st. Generation Interceptors, & Like wise He LOVES! to antaganize. It's something you just accept.
  11. rickjames
    PA
    Great news and the pics will be up tomorrow night. I have to pick the bike up and ride it home after work tomorrow. It should be the first day with decent weather since i purchased the little rascal.
  12. rickjames
    PA
    Here are the requested pics of the new to me scooter. I picked it up and immediately rode it about 90 miles back to my house. So far it seems to run like a raped ape, but i still need to pull the valve covers this weekend. I had a blast it was mostly state routes then a bit of interstate. I wont lie the speed snuck up on me a bit i looked down and found myself doing 90 at one point. I had real fun though on the b-roads though that little bugger is a hoot!!! 2012-05-15_23-03-09_440.jpg 2012-05-15_23-02-49_442.jpg 2012-05-15_23-02-04_753.jpg
  13. Apittslife
    Nice Looking 500, Glad to read she runs out well, Congrats!
