new vfr400 owner need a bit of help please
Discussion in 'Introductions' started by vfr400 owner18, May 3, 2008.
  1. vfr400 owner18
    vfr400 owner18 New Member
    hi vfr world
    just to start straight away i need some help im not sure if you can help me hopefully you can my vfr400 nc30 import has full tiga conversion kit on it so it did not have a under seat tool kit. heres the problem i want to change my spark plugs but do not no what spark plug spanner and socket i need to change my spark plugs with. i have a haynes manual but in the section spark plugs all it tells me is to use the under seat socket that came with it under stand my problem please help with maybe the sizes or specifications or enev a trust worthy internet site where i can buy what i need please help all the best nathan
  2. RVFR
    Sounds like a trip to Sears. Or Snap On. I would like to believe those plugs will be of a normal size as in whats in our bikes, to make sure just call up a dealer and ask for plugs, still believe they would be an over the counter item, maybe not, but think it would be. Then measure, then head to your local Sears and pick up the socket. not sure where'd you ever find that tool kit other than by luck on say ebay. good luck
  3. vfr400 owner18
    thxs ill have a try at that good idea
