New wheel bearings too stiff?
Discussion in 'Mechanics Garage' started by woody77, Apr 7, 2009.
  1. woody77
    woody77 New Member
    Palo Alto, CA
    How much drag should there be in new wheel bearings. Just picked up my wheels from the shop, and the inner races in the rear are tight, but smooth. Fronts won't turn at all with just my fingers on the inner races.
    seems stiff, but then this is my first experience with new wheel bearings.
    All the new bearings we put in the Hawk's engine spun freely, both before and after install.
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    If they don't spin with your finger they're too tight. They should spin freely, but not loosely.
  3. woody77
    woody77 New Member
    Palo Alto, CA
    I was worried about that. I'll poke more when I get them home (they're in the trunk of the car right now).
    May call up the shop and see what they say.
  4. CdnVffer
    CdnVffer New Member
    Ottawa, Canada
    Like FJ said a friend of mine had the same problem but when I went over to help we fixed the problem!
  5. squirrelman
    Chinese bearings ???
  6. woody77
    woody77 New Member
    Palo Alto, CA
    Found the problem, they're in tight against the spacer, so I can turn the both bearings and the spacer together as a set, but not a bearing individually. Outer race set too deep for the length of the spacer?
    Seems to be getting better as I move them by hand.
  7. woody77
    woody77 New Member
    Palo Alto, CA
    Only if the ones from Honda are...
  8. squirrelman
    HONDA, never will.
    Good move, woody.
