Newbie tire pressure question
Discussion in 'Mechanics Garage' started by Seattle, Apr 7, 2008.
  1. Seattle
    Seattle New Member
    Seattle
    Ok,
    I have Pilots on my bike, and I'm trying to figure out what air pressure I should be running. I've read that guys running all kinds of different pressures and I'm confused. Should I run them at 42psi or is there a more appropriate inflation. I should mention I have an oversize on the rear 180 55.
  2. Scubalong
    I have the pilot as well and I am always maintain 42 psi in the rear.
  3. mello dude
    Romania
    I usually keep 40 - 42 rear and 34 - 36 front.
    MD
  4. Seattle
    Seattle New Member
    Seattle
    Mellow,
    Should I error to the high side 36frnt / 40r ?
    Why does the manufacture put such a high pressure on the tire?
  5. reg71
    Sikeston, MO
    bout the same as me 35 front, 42 rear... I think that's what my manual said... I ran one set at 35-35 and I stuck like glue but I think the rear wore a little faster...
  6. mello dude
    Romania
    I really just follow the Honda recommendation and add a tolerance --
    + zero and - 2. I wouldnt go over the bike manuals 42 rear and 36 front.
    Tire manufactures will list what the tire can stand, but that doesnt apply to the paticular bike application. The bikes manufacturers recommendation should be followed as a starting point.
    MD
  7. Barrybullet
    Barrybullet New Member
    I run -2 psi under the recmd psi when riding solo and run the recmd. psi for 2-up
  8. bitterpil
    bitterpil New Member
    Northern Virginia
    I ride the the recommended PSI front and rear possibly -1. I check weekly with a dial gage. I ride solo most of the time but never know when the wife comes home hankerin for a ride.
    The mfgs designed handling charictrtistics are based on the recommended PSI. but different tires,different riding styles experience.... make changes as need dictates.
    Oh... pilot power 2cts
  9. Molsan
    Molsan New Member
    Red Deer Alberta
    I follow the Bike sugestions...mainly because there printed on the swing arm and easy to read.
  10. PingJockey
    PingJockey New Member
    Upstate SC
    Put some Shinko Stealth Tires on my '95 VFR and had similar concerns about proper pressures front and rear...
    I'm not sure if ALL tire makers agree about the quotes below but I had been running 36 psi in the front and 42 in the rear.
    Message:
    What pressures for front and rear 003's on my '95 Honda VFR750F? My owner's manual says 42 rear 36 front but that is for OEM tires. The 003 rear max. @ 783lbs. is 42 psi so I'm not sure what the recommended pressures should be.
    Thank you for your time. I am very happy with my Stealth tires. Just want to keep them at optimum pressures.
    Regards
    Thank you for contacting Shinko Tire U.S.A.
    We recommend running the max psi on the sidewall whenever possible and never more than 5 psi below for rider comfort.
    We appreciate you using Shinko Tires.
    Sincerely,
    Kyle Kosberg
    Western Power Sports/Shinko
    601 E. Gowen Rd.
    Boise Id 83716
    PH: 208-376-8400 EXT. 3427
    KKOSBERG@WPS-INC.COM
  11. ddlock7416
    ddlock7416 New Member
    I run 42 back and 38 in front rides smooth like always. Love my 95 vfr . I had 1100 bikes not run as good. Blows my mind..
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  12. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    On the 5th gen Honda recommends 36F, 42R.
    The higher the pressure, the less contact patch you have, and less tyre flex also.
    A lower pressure will increase your contact patch, and tyre temperatures.
    Too low a pressure will give too much tyre flex, much higher wear and handling will become heavy and unsafe.
    In winter when I go scratching I use 36R and 34F.
    I find if I go any lower on the front, steering gets too heavy/slow for my style of riding.
    Two up or on long trips I use 42R 36F.
    I'm using Rosso III's.
    I don't commute ever.
