No Brake Light w/ Front Brake
Discussion in '6th Generation 2002-2013' started by czargee, Mar 28, 2021.
  1. czargee
    czargee New Member
    Hi VFRers! I just noticed that my rear brake light does not come on when engaging the front brake. It does work when using the rear brake.
    Any places where I should check first? Your help is appreciated!
  2. fink
    fink Member
    Check the wires are plugged into the front brakelight switch. located on the front brake lever assembly. Easy way to test is to disconnect from switch and touch together. It could be a faulty switch which may be rectified by a bit of wd40 or contact cleaner. Switch itself is held on by 2 screws.
    czargee likes this.
  3. squirrelman
    only one screw on my bikes.......?
  4. fink
    fink Member
    Yes sorry. I made a mistake, its only one screw.
  5. squirrelman
    it' fine your only mistake was brexit. :Yo:
