No Fire 98VFR800
Discussion in 'Mechanics Garage' started by Corey L, Jul 5, 2020.
  1. Corey L
    Corey L New Member
    Ottawa
    Hey all, So I've come across an odd problem. I just bought a 98 VFR800 Yesterday, Started it to inspect it, Took it off the truck and started it again to pull it into the driveway. Went outside to start it and pull it into the garage and it would not fire up.
    Key into on postion
    Engine killswitch Set to run
    Fuel pump comes on and primes
    Hit starter and cranks but will not fire up.
    Bike In neutral, Tried with kickstand both up and down.
    Im very confused as to what may have happened in that 20 minutes and maybe sombody could help me out?
  2. RllwJoe
    RllwJoe Member
    We may need some more information.
    Has your '98 been ridden on a regular basis?
    What is it's history? Any recent repairs, or updates?
    How many km on the clock?
    Was the fuel in the tank fresh?
    Rust in the tank?
    Have you measured the voltage of the battery? If so, what did you find?
    Is there a mouse nest in the air box?
    Any of these could be helpful to know when looking for a solution.
    dhinson66 likes this.
  3. Corey L
    Corey L New Member
    Ottawa
    It was ridden atleast twice a week, Previous owner just took it off the road 3 weeks ago.
    Motor was rebuilt fresh last year by dealer.
    Just over 60,000 km(On everything but motor) Motor guessed to be around 15-20,000
    Fresh gas no rust
    Brand new battery
    Clean box
  4. Terry Smith
    I had my normally very healthy ST1300 flood on me and it wouldn't start. The fix is to turn the throttle full open then turn it over. The FI system works out that you want to clear a flood and shuts off the injectors while you do this. Then try starting normally.
  5. squirrelman
    have u checked for sparx ?
  6. Corey L
    Corey L New Member
    Ottawa
    Big thanks too you. It was indeed flooded, I did what you said and it started up within about 6 seconds of having it wide open and cranking. That's quite a cool feature.
    RllwJoe and Terry Smith like this.
  7. Terry Smith
    Woohoo!! Glad to hear that worked for you. Always do the simple stuff first.
  8. raYzerman
    raYzerman Member
    Millgrove, ON
    Many ECU's seem to stay in "enriched starting mode" if shut down before a certain engine temperature is reached. WOT is the fix, or let it warm up reasonably well before shutting down.
  9. dbuzz77
    dbuzz77 New Member
    Unknown
    South Lake, Saskatchewan
    when I used to snowmobile with a bunch of people some machines would flood on the trailer as you were towing if the gas was not shut off. something about negative draft sucking fuel through the carbs or something to that effect
