I just received a complete wire harness from the US. Plugged it and i still have no power to fuel pump. F1 light stays on, the ecu dosent give me any codes. The bike turns over. I checked the fuel pump relay all fuses, kill switch, kick stand switch im running out of ideas! Burnt ecu??? And i badly need the service manual its a 08
The service manual is downloadable https://vfrworld.com/threads/downloadable-parts-catalogs-and-service-manuals.3161/ http://www.vfrdiscussion.com/forum/index.php?showtopic=25946&st=0&p=311270&#entry311270 Dumb question - Why a new harness? Does the fuel pump work if you put 12v on it? If you have no fuel pumping its pretty much a certainty that the bike won't run as I'm sure you are aware..
