no power when I turn ignition
Discussion in '5th Generation 1998-2001' started by surfer1678, Sep 1, 2013.
  1. surfer1678
    surfer1678 New Member
    hello fellow riders I have a problem with the 98 Honda VFR 800 just checked out my wires and harnesses and noticed a splice on the red wire to the ignition switch it touched the frame then sparked and now I have no power at all fuses okay any advice would be helpful thank you guys n gals :)
  2. zoom-zoom
    zoom-zoom Member
    BC, Canada
    Have you checked the main fuse in the green connector to the front of the battery. It is a 30 amp fuse and may have been blown when the wire shorted.
  3. surfer1678
    yes I did check the fues im assuming the ignition switch burnt out. thanks for the response.
  4. christoph27
    christoph27 New Member
    I have had the same thing happen to me. It was an attempted theft and now I have no power and all the fuses are fine. So was it the Ignition switch?
  5. rjgti
    rjgti New Member
    regina sk
    start measuring voltage at the battery, post back what you have
  6. rjgti
    rjgti New Member
    regina sk
    you should have two 30 amp fuses and a 20 amp fuse to check first by the batterry
  7. christoph27
    I found the 2 30 amp fuses and checked the voltage is at 12.3. Where is the 20 am fuse located?
  8. rjgti
    rjgti New Member
    regina sk
    The wiring diagram says between main fuse b(30a) and engine stop relay
  9. christoph27
    I found all the fuses and the 30 amp I thought I checked was popped. Thanks for the help. I soldered the ignition back up and she started. I got to ride for the first time in 4 weeks. B-) Thanks!
  10. rjgti
    rjgti New Member
    regina sk
    Good to hear
