No spark
Discussion in '1st & 2nd Generation 1983-1989' started by AledoBill, Apr 27, 2019.
Tags:
  1. AledoBill
    AledoBill New Member
    Hi All!
    I'm Bill from western Illinois and I just picked up an 86 700 interceptor that has been sitting outside under a cover for 21 years. Just bought a new battery. It turns over but there is no spark to any of the plugs. What are the most common reasons for this? I have bypassed the clutch switch and I have the kickstand up. I have Clymers manual but its not very useful.
    TIA
    Bill
  2. bk94si
    bk94si Member
    Kill switch set to run?
  3. AledoBill
    Yes and all fuses are good. At least the fuses next to the ignition keys. Any other ones hidden throughout the bike? I have already restored a 78 CB750 but this is a whole new ball game.
  4. Thumbs
    Thumbs Member
    Bath(ish)
  5. squirrelman
    good idea to test compression b4 spending time or money, see what you have to work with.
  6. AledoBill
    Good point. That would be a bummer. The compression is good. I just need to figure out how to figure out where the system is breaking down. I bypassed the clutch switch and there is no stand switch.
  7. squirrelman
    check at the cdi box plug to see if it's getting power. (key and run switch ON )
  8. AledoBill
    That's a good idea. I imagine all the safety switches occur before that point. Do you know which wires bring power to the CDI off hand? Otherwise I can find a wiring diagram and figure it out. Thanks for the idea!
  9. AledoBill
    I figured it out. It was a bad kill switch. I took the little screw inside the assembly and little pieces fell out all over. Thanks for the help!
  10. squirrelman
    so it's running now ?
  11. AledoBill
    No. This is going to be a long term project. I had to drill the gas cap to get it open and it's a mess inside. I cleaned the carbs already but it still won't fire up with starter fluid. The spark looks weak. I think I'm going to clean all the connections and try again. I may replace all the carb jets as well. I'm glad I have my cb750 to ride while I work on this one.
  12. squirrelman
    drain and flush the fuel tank or bottle-feed the carbs at first. weak spark? try a jumper battery or make sure you have 12.6 volts on yours.
  13. Terry Smith
    New Zealand
    Weak sparks may likely be a result of general corrosion in terminals. I'd suggest you disconnect them all and clean then apply some dielectric grease. I had a similar problem on my ST1100 and the root cause was corrosion within the red connector which feeds power to/from the right switch pod. This manifested as low voltage at the ECU. Good luck.
