No Start '93
Discussion in 'Mechanics Garage' started by WH93VFR, Jun 20, 2009.
  1. WH93VFR
    WH93VFR New Member
    Red Deer Alberta
    Good Day,
    I am riding a '93 VFR and have a no start condition. This machine is my daily, fun commute in the city. The battery is new last fall, shows 12.5 V at the posts, no blown fuses. When the ignition switch clicks over to ON, no lights, starter, oil light, zero.
    Anyone with history of these symptoms?
    Thanks in advance!
    Dale M.
  2. betarace
    betarace New Member
    Middleburg, VA
    bad ground?
  3. squirrelman
    Look atop your starter relay for melted wires and check main 30 amp fuse, paying special attention to the 4-wire plug.
    Clean/tighten both battery connections after doing the same to main ground wire.
    Check plug connection between ignition switch and main wiring harness.
    Try a different battery.
