Octane preferences
Discussion in 'General VFR Discussions' started by PuCaudata, Mar 13, 2008.
  1. PuCaudata
    PuCaudata New Member
    Great Falls, Montana
    Hello all,
    I just bought a 2007 VFR. I'm wondering what octane fuel you guys run in yours. The only thing that's available in Great Falls is 91. Should I pursue higher octane gas or is 91 fine? Thanks for the input.
  2. v4pwr
    v4pwr New Member
    cleveland, ohio
    check in your owners manual for the minimum to run. my bike requires only 87 but i run 93 mainly for the detergents that are in the fuel. every once in awhile in put cam2 100 mainly just because you cant beat the smell of racing gas, however i think the cam2 is not cat. conv. safe if you have one. i dont see any problem with 91 octane unless the owners manual says to go with something higher which i think is probably not the case.
  3. PuCaudata
    The owner's manual says 86 octane is acceptable. Personally, I wouldn't put 86 in my lawn mower. I just wondered if anyone noticed any operable differences in running higher octane fuels.
  4. powderrecon
    powderrecon New Member
    Seattle
    91 should be fine. I run Chevron 92, and have been thinking about bumping it down a notch, and seeing if I notice a difference.
  5. v4pwr
    v4pwr New Member
    cleveland, ohio
    i havent noticed any difference as far as performance change with different octanes. the only change i ever noticed was it seems to have a deeper sounding exhaust with the racing gas. but i agree i personally would not run less than 91
  6. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    I always run the highest available at the pump, partly due to habit (old air cooled high compression engines). Generally, I don't think you can go wrong with the higher octane. I have used 89 in my SV650 once or twice, since that was all there was in the middle of nowhere. I didn't notice any difference. Most new four valve engines have an amazing tolerance for lower octane fuels due to their combustion chamber design, but I would still stick to at least the mid-grade (typically 89 in good ol' CA).
  7. RVFR
    Oh No, a fuel thread, almost as bad as an Oil or tire thread. LOL FWIW Chevron supreme with techron. If I could find something hotter I'd use it.
  8. Lgn001
    Lgn001 Member
    Just think; if we had two-stroke engines we could combine the fuel and oil discussions into one thread...:biggrin:
    Hey, even better: If we had those big single-wheel vehicles with two stroke engines, we could combine...
    I'll stop now.
  9. derstuka
    San Diego, CA
  10. Mac
    Mac New Member
    NC High Country
    BP 89, can't tell as it runs any different than the 93. So, the only difference I feel is that my hip pocket seems a little thicker.
    Mac
  11. hondawolf
    hondawolf New Member
    Livermore, Ca
    I usually run 87 in my 04. I've done quite a few freeway runs and tried different octanes. Never seem to notice a difference. So usually stick to the 87, but from shell or chevron. Not ampm or whatever's the cheapest. Also run a can of fuel system cleaner through the bike every oil change, about 4k miles. Don't run the bike hard, or hardly going into the higher rpm's unless I'm getting on the freeway. If I ran the bike harder, I might notice a difference with the octanes?
  12. elf800
    elf800 Banned
    dallas
    yeaaah another confusing situation.. 91 is fine just remember you got a brand new bike ohh it holds 5.8 gallons so if u run it down lets say you buy 5 gallons to fill up are you really worried about 50 cents to a dollar per fuel up????the better the oil the better the gas the better the ride for the long hual.................................................
  13. JTC
    JTC New Member
    Watts, CA
    i likey that thar deseal jus fine! Be just a wee smoky but me don't done mine dat much. :yield:
  14. PuCaudata
    The main concern is that 91 seems to be the highest octane offered in this town...if something higher was needed, other arrangements would have been sought.
  15. junktionfet
    junktionfet New Member
    Raleigh, NC
    I used 93 octane before I discovered the bike is designed to run on "86 or higher". There is of course no difference in rideability that I can detect, and no harm using either flavor. Because the bike has been specifically engineered (timing, compression ratio, etc) for "86 or higher", I now use 87 octane.
    Many people believe that 93 octane usually contains a lot of special exclusive additives which help keep the injectors, valves, and combustion chambers clean. Some gasoline vendors may actually include such additives in their fuel, but many question if the quantity they use is sufficient to really keep the engine clean without additional treatment over time.
    Personally I've seen more aggressive results (visually anyway) by running a bottle of BG 44K or a similar Naptha based solvent every 16,000 miles or so. A before and after shot with fiber optic scope is all you need to see :)
  16. derstuka
    San Diego, CA
    My bike runs fine on 87. I bought 89-91 for years, thinking it was better for it for some reason. I only run 87 now. If your vehicle is not spark knocking and designed for 87, I think "where" you buy your gas (like Chevron, Shell, etc,) is more important than the octane level. I believe it is possible for cheaper gas to leave more gunk and deposits in your engine over time than a quality gasoline. I also noticed that my truck can go further on a tank of gas when filling up at a 76, or chevon, than an ARCO station.
  17. hondawolf
    Livermore, Ca
    I agree, it's all advertisment about the additives, but would rather do it myself and then I know. If it runs fine on the 87, then I'll run the 87.
  18. vfr2k2
    vfr2k2 New Member
    Ontario, Canada
    Octane
    Octane rating? Don't worry about that!!!
    Just block off the pair valve, gut the cat, replace the cans, change the rear sprocket, don't use Dunlop tires, use the very best synthetic oils, change the filters to K&N and just give an expert "listen" yourself to judge how well the bike performs when using the cheapest gas out there and you will see the bike "runs just fine".
    I'd buy the higher Octane and foget the rest. But that's just my opinion. I've only been riding for 50 years.
  19. RVFR
    Avgas.. FTW
  20. Nungboy
    Nungboy New Member
    Tucson, AZ
    Didn't we just dance this dance LAST WEEK??!!
    86 cha cha cha or sometimes
    88 cha cha cha (when I feel rich)
    "Mr. Clark, I give it a 86, I can dance to it..."
