OEM chain listing vs actual available
Discussion in 'Mechanics Garage' started by Peter Jackson, Apr 28, 2023.
  1. Peter Jackson
    Peter Jackson New Member
    Trying to replace my chain on my '14 800D. The owners manual states DID 525HV3 but supplier says they dont have this, not even on the DID website. Sprockets are OEM. Im looking for a gold/bronze chain. Any ideas for a replacement?
  2. bmart
    bmart Insider
    Charlotte, NC
    DID and RK are your best choices. Use a rivet link, not a clip, if you can. Most 525 applications have gone to 520, as those have gotten stronger over the years. If you change size (520, 525, 530-what I run on mine) you will need to change the sprockets too, which you should do anyway with a new chain.
    Tons of choices available. Have you tried SprocketCenter or Kurvy Girl?
  3. Peter Jackson
    Thank you for the info. I thought the number had something to do with pitch. Now understand it's about weight/strength. Honesty my sprockets look fine but I will look closer and count my links. I'm assuming using a rivet link chain will require some type of special? I'll check out those sites.
  4. Peter Jackson
    Looking at a DID 525 ZVMX Super Street X2 to replace the OE chain. Any recommendations for a rivet tool? Obviously this is only get used a few times so not looking for an expensive commercial unit.
  5. Cyberob
    Cyberob New Member
    Netherlands
    Peter Jackson likes this.
  6. bmart
    bmart Insider
    Charlotte, NC
    It does.
  7. Peter Jackson
    I was sure it did but I'm getting mixed info. My sprockets look very good. I'm the second owner so I'm not clear on the chain/sprocket service.
  8. bmart
    bmart Insider
    Charlotte, NC
    Chains and sprockets wear each other out. I too have changed only some of the components, but know that they'll all wear faster. You'll have to run the cost #s for yourself to see what works for you. Frequently the teeth hook, you can see this easily and also tell by turning the rear wheel backward. It'll sound terrible and throw fits and spurts.
    And one from a friend's Ducati...they were still riding it with power delivery issues. lol
