OEM Heated Grips Installation Issue
Discussion in '6th Generation 2002-2013' started by Balu, Nov 7, 2014.
  1. Balu
    Balu New Member
    Hello,
    I'm having an issue connecting the harness negative to the bike. In the instructions it says "Turn Signal Harness" so I took of the side and disconnected the turn signal and also followed the cable that goes from it up a bit into the main harness but I don't see anywhere where I could connect this. Do I maybe have the wrong part (perhaps this is for a older VFR?) or am I just completely in the wrong place?
    If anyone has done this before or can point me in the right direction it would be greatly appreciated. I've attached a couple pictures.
    Thanks!
  2. Scubalong
    If it negative you can hook it up anywhere that have ground.
