OEM Top Case Mounting Question 6th Gen
Discussion in '6th Generation 2002-2013' started by Jelorian, Sep 14, 2020.
  1. Jelorian
    Jelorian New Member
    SF Bay Area
    I have the factory OEM side cases on my 02. For those of you that have the OEM top case, do you have any pics showing how it is mounted? Do you lose the grab handles? I'm debating trying to source one, but wasn't quite sure how it mounted to the back of the bike.
  2. Old Faithful
    Old Faithful New Member
    This is my 2010 with OEM Topbox fitted.... the grab handles are incorporated in the Topbox Mount. E8CA3866-0EE6-4CE0-8278-FB966A7EFBB6.jpeg
    Jelorian likes this.
  3. Jelorian
    Jelorian New Member
    SF Bay Area
    Thanks for the pic. Do you happen to have one closer showing the attachment to the grab handle locations? Thanks much!!
  4. skimad4x4
    France
    French Alps & London
    Does this help..
    The OEM side cases(panniers) and OEM top box carrier both attach via the "Frankenbolts" which the pillion handles currently attach to.
    However the OEM top Box mount includes pillion handles meaning the existing pillion handles will need to be removed and become surplus to requirements.
    The top box mounts have a flexible rubber base designed to seal down neatly to the rear fairing panel without any significant gap. Where both a top box mount and an OEM rear bags (Pannier) carrier are fitted they share the same Frankenbolt mounting, with the rear carrier plate located below the top box mount so that the flexible rubber base deforms slightly to hide the join.
  5. Old Faithful
    31ADC6DA-AAFC-42CE-B5FF-3070C2BE7D86.jpeg 31ADC6DA-AAFC-42CE-B5FF-3070C2BE7D86.jpeg BDA87F6B-0D5C-4206-9E94-9357F58CA78A.jpeg 181C2378-C77A-4319-A443-71DD91DE4AD9.jpeg 3B1EE0D3-788F-46E1-94CE-D5670DCD2D0C.jpeg
  6. Jelorian
    Jelorian New Member
    SF Bay Area
  7. Old Faithful
    No worries ... Cheers mate.
