OHLINS FORKS ON A 5th GEN ANYONE? HEARD OF? OR SEEN THIS ON THIS SITE?
Discussion in '5th Generation 1998-2001' started by 808VFR, Oct 27, 2008.
  1. 808VFR
    808VFR New Member
    In my house in SD Cali.
    Be it Ohlins or other inverted forks. Is it possible to replace/rebuild the front suspension to this?
  2. mello dude
    Romania
    I dont know of to many here on vfrWorld, maybe SafeT.
    http://vfrworld.com/forums/modifications/16855-holy-cow.html
    But a lot more guys on VFRD have done the FrankenForker challange. I did mine but its based on the stocker upper tubes and triples. Check links below. Either way its a ton of work, you need to be a very good mechanic.
    veefer800canuck over on VFRD is a great resource.
    More stuff --
    http://www.vfrdiscussion.com/forum/index.php?showtopic=40656&hl=
    That ought to be enuff to get your head spinning......lol
    MD
  3. RVFR
    Yep Safe-T has em plus a lot more...
  4. Glockem
    Glockem New Member
    Manasshole, Virginia
    Or you can just send your forks to Dan Kyle and get them rebuilt to your exact specs with Ohlins internals, springs, shim kit, valves, etc. instead of shelling out the big coin to get real Ohlins R/T forks. Plus if you get the radial forks, you have to reconfigure your brake system with radial brakes, spacers, etc.
  5. Charles B Muller
    Charles B Muller New Member
    clemson S.C.
    HI' I'm new to the sport bike class,and just pick up a 5th gen. that has a slight been in the top of the front fork.(NEED HELP to find the best way to fix or re-place or upgrade )
  6. mello dude
    Romania
    Hi Charles - probly starting a total new thread for you bike with pictures would be a good way to start for you. :smile: In the mean time check out the links below.
    Good luck,
    MD
