Oil change
Discussion in '6th Generation 2002-2013' started by ciantrius, May 3, 2019.
  1. ciantrius
    ciantrius New Member
    Hi,
    I picked up an 02 VFR 800 late February for commuting, and as I've done about 5k since then I guess an oil and filter change is in order.
    I've got genuine Honda parts and the bike is unmodified.
    Are there any common gotchas I need to keep an eye out for?
    Cheers, Jon.
    Sent from my ONEPLUS A6013 using Tapatalk
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Main thing is to be gentle with the plastic push pins, especially the ones on the underneath of the fairing.
    You push in the center with a small screwdriver or such, then the pins can be removed. Sometimes you have to
    fit something under the larger diameter head and, gently, lever it off.
    You don't need to remove both sides of the main fairing. Just the left side, and the black inner part in front makes
    it a bit easier.
    ciantrius likes this.
  3. jstehman
    jstehman New Member
    And you will probably get oil on the front exhaust headers when you undo the filter.
    Sent from my SM-N950U using Tapatalk
  4. NorcalBoy
    Wrap with foil, peel off when done, also insulates you from the heat just a tad.
    jstehman likes this.
  5. squirrelman
    for better engine life, pre-fill the oil filter w about 1/2 quart.
  6. ciantrius
    That's a great tip!
    Oil change done, only two casualties, one of the plastic bolts from the bottom front of the fairing broke and one of the rubber mounted nuts that holds the fairing under the right bar failed.
    Minor things and not bad for a 17 year old machine with 53k on it.
