oil level check procedure
Discussion in 'Mechanics Garage' started by Metzman, Jun 17, 2015.
  1. Metzman
    Metzman New Member
    On a Gen2 VFR,
    is the oil level checked with the bike on the side stand or standing straight up?
    Do you insert the dipstick all the way in, threaded in, or do you rest it at the top of the threads to get the oil level?
    Seems like stupid stuff here I know, but it makes a big difference. Too much oil can be just as bad as too little...
    Thanks...Metz
  2. mofo
    mofo New Member
    Orange County Ca.
    I'm assuming there is no sight glass on a gen2? All the hondas I've had the right way to do -per owner's manual- was bike upright and the dipstick threaded all the way in.
  3. Metzman
    Metzman New Member
    You are correct, no sight glass.
    That is what I am assuming also, but my Yamaha is upright dipstick resting in the hole (not threaded) and my Buell is on the side stand threaded in...
    Thanks...Metz
  4. Underoath87
    Underoath87 New Member
    Orlando, FL
    A bit underfilled is definitely better than overfilled.
  5. squirrelman
    Hold bike up straight and rest the dipstick on top of hole, not threaded in.
  6. 34468 Randy
  7. mark641
    mark641 New Member
    RAINTON, NORTH YORKSHIRE
    Level ground...up on the centre stand...take out dip stick and wipe it clean, rest it back in place, then withdraw and check.
    Owners/factory manual will state the correct method
