oil line banjos
Discussion in 'Mechanics Garage' started by lnb001, Sep 10, 2011.
  1. lnb001
    lnb001 New Member
    Virginia
    I was installing Dave Dodge's oil mod today ('85 vf700f) and noticed banjos did not come with the kit. I seem to have misplaced the OEM banjos (or at least I think) so I am not able to finish the install. Can anyone confirm what the stock banjos for the oil line at the head look like? I assume they are identical to the banjos for the brakes/clutch, etc. only longer?? I only ask cause I have two other bolts laying around that have the sealing washers attached. The threads are the right size and everything and the shaft is sqaure near the head of the bolt, but there are no oil holes. This is driving me crazy as I just took the stock ones off to repaint motor a few weeks ago!
    Thanks,
    Lucas
  2. TOE CUTTER
    Here is a pic of one, it has a triangular shank on it where the oil flow's around it.
  3. lnb001
    lnb001 New Member
    Virginia
    YES! Thank you! I was starting to question the ones I had since there were no oil holes but I figured that was why the shank was not round... Just saved me about $25
  4. TOE CUTTER
    No problem.
