Oil Overflow When Motor is Turned Off
Discussion in '6th Generation 2002-2013' started by stewartj239, May 7, 2007.
  1. stewartj239
    stewartj239 Member
    Syracuse, NY
    I have a new '07 and whenever I turn off the engine, it spits oil out of the overflow tube onto the ground. I initially figured that it was because the factory overfills the crankcase to error on the safe side. I changed the oil at 300 miles and it is still doing it. Is this normal? There's no way that a new bike should be leaving oil spots all over the garage floor!
  2. RVFR
    Not normal, where's the oil level on the site glass after the fact?
  3. elizilla
    elizilla New Member
    Michigan
    Is there oil in the airbox?
  4. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    Nope, thats not normal. Sounds like a warranty issue to me.
  5. VaRollOn
    VaRollOn New Member
    Cary, North Carolina
    they may have screwed up PDI by overfilling the oil. Check the airbox like they said. Any way you cut it, its not supposed to leak oil. It's a Honda VFR not a Sportster.
  6. stewartj239
    stewartj239 Member
    Syracuse, NY
    At this point, this may be what the problem was. It has now only done it once since I changed the oil, and it was the first time the engine was run following the oil change. Up until now it has done it every single time. I put in 3.3 quarts and looking at the window on the crankcase window, it is just below the high mark. Before, it was just above the high mark.
