oil pan threads
Discussion in '1st & 2nd Generation 1983-1989' started by neelsonwheels, Mar 20, 2010.
  1. neelsonwheels
    neelsonwheels New Member
    Gainesville, FL (for academics only:-)
    So I noticed a small oil leak coming from the drain bolt. I go to tighten the bolt and it doesn't. I unscrew the bolt and notice metal shavings in the bolt threads. I try a new bolt and it doesn't tighten like the old one.
    What are my options? Do I need to start hunting down a new/used oil pan?
    TIA... this board and folks on it are awesome!
  2. Dukiedook
    Dukiedook New Member
    Kansas City, USA
  3. neelsonwheels
    Thanks for the link and idea. That makes sense and should solve my problem.
  4. reg71
    Sikeston, MO
    I think Randy just did that a few months ago. I used to have quite the issue with mine dripping a little, but I try and swap the copper washer every oil change now, and that seems to help a little. I just snug it up pretty good, but I suppose if you are real particular, you could go with the torque wrench.
