Out with the old....
Discussion in '5th Generation 1998-2001' started by RVFR, Apr 4, 2016.
  1. RVFR
    .... In with the new Penske
    Nice... wasn't to bad for an install as far as installs go room for it to be a lot worse. and no skinned knuckles
  2. TOE CUTTER
    Did you ride it?
  3. RVFR
    Not Yet. :( Forks are now on there way Back from Jamie. With luck they should be here before the week is over, so hopefully the vfr will get a full shake down this weekend. ;) With fresh redone rims, new sticky tires, and fresh all the way around suspension, can it get any better?
  4. duccmann
    Nope, you pretty much nailed it brotha....now get out a flog it
