Accessories for Sale SOLD-Parting out a 4th gen
Discussion in 'Classifieds' started by jethro, Jun 26, 2022.
  1. jethro
    jethro New Member
    Parkville, Mo.
    I bought a wrecked 4th gen that has a good front end on it near as I can tell. That's all I need off of it and am going to part the rest. There is no plastic or gauges and the tank is smashed and cut open. Let me know what you are needing and I will see if I have it and what shape it's in.
  2. LannyL81
    LannyL81 New Member
    Green Valley, Arizona
    Any chance this had a speedo healer of some type on it?
  3. jethro
    jethro New Member
    Parkville, Mo.
    I'm not sure where one would be located, but I would say no. There were no instruments and I have removed the sender off the sprocket cover and it just plugged into the harness.
  4. LannyL81
    LannyL81 New Member
    Is the speed sender good? I have been thinking of trying to mod the signal output to correct the error.....in effect make my own speedo healer.
  5. jethro
    jethro New Member
    Parkville, Mo.
    I am assuming it is, but don't know how to test it. Do you know the procedure?
  6. LannyL81
    LannyL81 New Member
    There is a procedure in the Service Manual, requires a complete wiring harness and battery so that battery voltage is applied to the sensor, then measure the output voltage while turning the rear wheel.
    Last time I did this was by connecting a battery across the sensor terminals and using an oscilloscope to look at the output signal.
    What kind of price are you thinking? I just want one to play with...my VFR does not need one.....so not worth much to me.
  7. the borg
    the borg New Member
    Do you have the OEM muffler?
