PC3+(Local Honda Shop*2)=Owner Need to Kill Someone
Discussion in 'Mechanics Garage' started by Cyborg, Jul 2, 2009.
  1. Cyborg
    Cyborg New Member
    During the VFR's 32k check I got the local shop to install a PC3, during which they were supposed to do a custom mapping. When I got her back the o2 eliminators were not installed. I plugged them in and started riding only to have the response rough, especially when hitting VTEC. I took the bike back, told them about the o2s, the roughness and I 2wanted them to redo the custom mapping. Today, I got the VFR back only to find the o2 eliminatos in a bag again. The FUCKING IDIOTS didn't redo the map, their solution was to plug the o2s back into the system! I have noticed VTEC is smoother now but wanna know, should I
    A) leave things as is
    B) reinstall the eliminators and map myself
    C) burn the damned shop to the ground
  2. steven113
    steven113 New Member
    Pensacola FL
    I would take it back and make sure it is done right! between the cost of the pc3 and mapping it is no cheap affair. After all you did all of this to have your bike run better!
  3. Cyborg
    Cyborg New Member
    That's exactly why I took the bike back and their solution was to remove the eliminators!
  4. squirrelman
    OK, why were you not capable of doing the work yourownself??
  5. Cyborg
    Cyborg New Member
    I am fully able to do it myself, but the shop had a deal going where if the PC3 was bought there, they'd do a dyno-custom map...
  6. Action
    Action New Member
    Albuquerque
    Take the bike back and explain that you are tired of crap service and you want to watch them reinstall the 02 elims and preform the custom map. I hope by custom map you mean they are putting it on a dyno. If they can't even manage to plug in the 02 elims, what kind of mechs are doing the tuning? That's why I would I would want to watch and make sure my air/fuel mixtures were good.
    Action
  7. VFRShorty
    VFRShorty New Member
    NW Oregon
    Make the shop do what they were supposed to do, and if that fails OPTION C! :thumbsup:
  8. Cyborg
    Cyborg New Member
    Ok, timeline format for those unable to read my first post (all times approximate to within 15 minutes):
    May 29th, 1645hrs: Got VFR 32k service and PC3 installed, received o2 eliminators in bag.
    May 29th, 1930hrs: installed o2 eliminators then rode bike, noting rougher ride
    May 30th, 1200hrs: reported the incorrect PC3 install (along with the clusterfuck they made of my battery accessories routing) and made arrangements to remap the PC3.
    July 1st, 1700hrs: Turned in bike for remap, had to explain problem and arrangement 3 times to shop tech.
    July 2nd, 1715hrs: recieved bike with o2 eliminators in bag, advised by service rep (tech who did work was already gone) that since the roughness started when the o2 eliminators were installed, they removed them and plugged the o2 sensors back in instead of remapping a damned thing! 20 minute argument got nowhere.
    To remove any possible doubt: The shop is not competent to handle anydamnthing that doesn't have a Honda stamp and beyond filing a complaint with the general manager and Corporate, I will not waste anymore of my time trying to get them to do their damned job. Now, should I leave the o2 eliminators out and stay with whatever mapping that's there or put them back and install the M111-001 map?
  9. Yosh70
    Yosh70 New Member
    Saskatchewan Canada
  10. Cyborg
    Cyborg New Member
    Too late, I've already ordered from Amazon.com the Lord of Nightmare's book Things to do to Beings who Tick Me Off...
  11. stoshmonster
    stoshmonster New Member
    Cyborg,I have a question for you. How do your O2 Eliminators work? Do you unplug the pigtails for the O2 sensors and plug your O2 Eliminators directly into the wire harness plugs? This would leave the pigtails from the O2 sensors hanging unplugged and completely eliminating the O2 sensors from the circuit. Or do your O2 Eliminators plug in-line with the O2 sensors,which leave the O2 sensors still in the circuit? I run something a bit different on my bike that I'd like to show you,but I need to know how your O2 Eliminators work first.
  12. Cyborg
    Cyborg New Member
    They plug in place of the sensors and leaves the sensor connectors dangling...
  13. Action
    Action New Member
    Albuquerque
    For the immediate future, why don't you install the 02 elim's and run Cozey's map or something similar. That way you should be able to ride comfortably while you decide what's next.
    Action
  14. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    Ummmm...not to take the shops side here but.........
    They cannot legally remove or bypass any part that is emmisons related.
  15. stoshmonster
    Alright,thanks Cyborg. I'll PM you with some pics and info.
  16. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    In Cyborg's defense, on his July 1st trip when he returned to the shop with the O2 elims in place and was there to get a map, they should have thrown it on the dyno and properly mapped it. At that point and time they were not removing or bypassing anything emmisions related, they were simply tuning it properly.
    I would install the O2 elims and find a map that works best. If you aren't running a crappy map for too long, the worst you can do is load a crappy map and have a poor running bike...in which you can load a different map and see if that works better.
  17. Cyborg
    Cyborg New Member
    That may excuse the initial one but not the second and I don't think either was because of any legal concerns either. Here's why:
    Dec 05: Shop did the VFR's 8k check using the maintenance schedule for an 02 Magna because it and the VFR "both have V4 engines", replacing plugs 4k miles before they were even due for inspection. The manager told me I didn't need to be questioning the work of his trained techs and the nerve to point out that at $149 I got a bargain, given the parts were $120 and the remaining $29 had to cover 3 hours of labor.
    May 09: Tech left the o2 eliminators uninstalled without explanation and did not properly route accessories to battery. Turn signals, working before, were inop when I picked up the bike, something the tech knew about yet did nothing because "it wasn't on the work order", he also did not document it, tell the service manager or warn me (I found out about the signals in rush hour traffic!). While correcting the battery clusterfuck, I found the security module's positive and negative leads connected to the battery negative, which shorted out the signals. I reported all to the Service manager who and he told me to bring the bike in for remapping with the o2 eliminators in place.
    July 09: See above
    So, you can see why my patience and faith in the shop is, shall we say, somewhat limited...
  18. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    Find ya a different dealership, these guys are jokes for anything more than an oil change... and I wouldn't even use them for that. I have the same problem with my local Honda shop and they are one of the largest in the midwest. Closest shop to me worth a crap is almost an hour away but I don't it. I get a fun relaxing ride to and from there and the people there are extremely awesome. If it wasn't so far, I would be ordering small and large parts from them as well, but the parts guys at my local Honda are pretty good, just not the wrenches.
  19. Cyborg
    Cyborg New Member
    Agreed but the nearest Honda shop is a full hour away and right now my riding endurance is limited due to recent knee surgery...
  20. mrich12000
    mrich12000 New Member
    Calgary, Alberta.Canada
    Small claim court,with a statment of claims for poor service.
